no start 6.0
Old Aug 18, 2010 | 10:21 AM
R&A's Avatar
R&A
no start 6.0
stoped to get fuel filled tank and tried to start but would not, scaned pcm and found injector high pressure was only 288 pounds any thoughts on what could cause it to drop pressure
Old Aug 18, 2010 | 11:18 AM
bismic's Avatar
bismic
Welcome to FTE.
I would think the pressure you are quoting is the pressure for the high pressure oil.
There are a number of things that can be a problem:
1. bad sensor
2. bad wiring
3. oil leak
4. bad high pressure oil pump (HPOP)
What year is your truck, and any mods? Also, what was the specific code?
Old Aug 18, 2010 | 12:17 PM
R&A's Avatar
R&A
it is the high pressure oil no codes sensor is good and found no leaks talked to ford service and they sold me what was called a connector kit
Old Aug 18, 2010 | 01:13 PM
bismic's Avatar
bismic
Can't help you any more without information.
As mentioned before - Need to know what year your truck is.
Also, what is the part number of the connector kit?
Was it Ford that found no leaks? HPO leaks are internal.
Who scanned for codes - Ford? I ask because some scanners do not pick up all the DTC's.
Old Aug 19, 2010 | 06:22 AM
R&A's Avatar
R&A
its an 06 i scaned it and the part # 4c3z9b246-f it has something to do with the ipr. there was also a fitting so i could put shop air to check for leak down
Old Aug 19, 2010 | 06:30 AM
bismic's Avatar
bismic
Does your scanner support CAN protocol? If not, it is not capable of picking up ALL the codes.
The part is the replacement part for your snap-to-connect (STC) fitting on your HPOP discharge. A common issue for 05's and early 06's.
If that fitting is bad, I would have expected leaks on an air test. If you did not command the IPR closed on the air test it would not have been a valid test.
Old Aug 19, 2010 | 08:03 AM
R&A's Avatar
R&A
my scanner does not have can and i did not do the air test because i could not command the ipr
lethal01
Jan 22, 2015 12:44 AM
drs041
Jan 28, 2014 04:01 PM
bobbyt89
Feb 18, 2013 10:07 PM
TDean
Nov 8, 2008 10:30 PM
ATCRTP
Jul 16, 2008 01:43 PM
