Battery light flickers sometimes???
Old May 6, 2018 | 06:17 AM
Christopher Pooler's Avatar
Christopher Pooler
Battery Flicker
I know this thread is ancient, but If you ever come across this problem on a 7.3, it is very possible that your IDM(Injector Drive Module) is about to fail. May have water inside causing this symptom. I changed my IDM, and lo and behold, it went away.
Old May 9, 2018 | 12:44 AM
brian42's Avatar
brian42
Veteran: Navy
In all the years I've owned Ford trucks, every time my battery has light come on it was an alternator issue.
Old May 9, 2018 | 04:54 AM
Whitey Ford's Avatar
Whitey Ford
FTE-Spread The Knowledge
A simple $3 digital meter in the cigar lighter would see a failing alternator that can and will take the batteries with it, quickly. The thing to watch is the morning voltage and drop under load, on the first start.
Old May 9, 2018 | 06:16 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Some brake controllers have voltage readings on them as well, I know my Tekonsha P3 does.
Old May 9, 2018 | 10:43 AM
SpringerPop's Avatar
SpringerPop
Yup. That's the mode my P3 rides around in about 98 percent of the time.
Pop
rustypierce
Dec 6, 2016 12:51 PM
Plankton
17
Oct 10, 2016 05:09 PM
proudfrog
Jul 1, 2016 07:49 AM
Damifiknow
Aug 14, 2015 03:50 PM
036.0stroke
Sep 25, 2013 10:07 PM
