HELP
Old Aug 18, 2010 | 07:58 AM
jerm032208's Avatar
jerm032208
HELP
I have a 1985 ford f-150 4x4 with 300 straight six ,I need to know what vacuum lines I need to run tryin to eliminate smog ect. Just need a bare motor.
Old Aug 18, 2010 | 09:37 AM
nstueve's Avatar
nstueve
elimination of the smog pump will not gain you anything but being illeagal if your truck ever has to be smog tested... Besides that you'll need to jump down to the older truck forum for the answer... this is the 1987 and newer forum... You'll get a better response there.
Old Aug 18, 2010 | 10:01 AM
JMC302's Avatar
JMC302
I had an 85 F150 with 300-6 prior to my current rig. Since the smog pump pushes air into the system after any computer control all you have to do is pull the pump and plug all vacuum lines...at least that is what I recall.
X2 about jumping down to the other forum...great guys there as well and will help you out with whatever questions you have.
kwrules
1983 - 2012 Ranger & B-Series
Dec 9, 2012 07:56 PM
chevyassasin
May 28, 2010 12:42 PM
HaroldCallahan
Nov 7, 2004 09:42 AM
Cheap Monster
1978 - 1996 Big Bronco
Apr 14, 2002 08:14 PM
killer4x4
13
Jan 26, 2002 03:03 AM
