Quick question?
Old Aug 17, 2010 | 11:45 PM
73 ford guy's Avatar
73 ford guy
Quick question?
I'm about to pick up my cam tomorow and I just wanted your opinion on it. I'm going with a comp cam 33-248-4
COMP Cams 33-248-4 - COMP Cams Xtreme Energy Camshafts - Overview - SummitRacing.com
It was reccomended by a VERY highly respected FE engine builder that has been on here previously and owns his own shop specializing in FE's not naming any names.
Anyways heres my build:
428 bored .030
d2teaa heads with cj valves
edelbrock performer rpm intake
770 holley offroad truck avenger
trw forged pistons 10:1
crane fireball electronic igniton
headers
5:13 gears
44" tires
Looking for bottom end torque and comp suggested a slightly milder cam but I thought I'd see if anyone has any experience with this one.
Thanks in advance for any help
Old Aug 18, 2010 | 10:16 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
I would question whether or not you are really going to get 10:1 with TRW pistons, what's the part number on those pistons? It might be much higher than 10:1.
I would also question whether or not you need such a long exhaust duration with the bigger CJ valves. When I built my 390, I used a "square" cam - same duration for intake and exhaust, because I used CJ exhaust valves.
However, I think you're in the right ballpark. But I'm no expert engine builder, neither.
Guys?
Old Aug 18, 2010 | 12:11 PM
73 ford guy
Pistons are 2287p. They are either 10 or 10:5:1
Old Aug 18, 2010 | 01:15 PM
krewat's Avatar
krewat
Are those Chevy pistons?
Old Aug 18, 2010 | 08:55 PM
73 ford guy
.........no
Old Aug 19, 2010 | 04:01 PM
jmf66's Avatar
jmf66
That's a hot cam with 230/236 duration @.050 No torque down low, but you should have a mean sounding idle
Old Aug 19, 2010 | 04:40 PM
73 ford guy
No torque down low?? That's kinda what I need. My last cam was a 343941 crane which had just a slightly milder spec. It was advertised as a tow/4wheeling cam used with a 8-10:1 compression. It worked pretty good with my rebuilt 390...
Old Aug 19, 2010 | 06:43 PM
krewat's Avatar
krewat
When I checked that TRW number, they were Chevy pistons?
Old Aug 20, 2010 | 08:29 AM
jmf66's Avatar
jmf66
I have to admit that my experience with cams has been with the small block and not the FE engine, so maybe someone else can chime in about big block cams. With more duration, the Comp cam should operate at a higher rpm range than the Crane... i.e. less torque down low. It all depends on what you want. At least you have the Crane as a starting point.
