whats a "knock" ?????
Old Feb 15, 2003 | 06:42 PM
gingerbreadmaniac's Avatar
gingerbreadmaniac
In my 85 300 i6 when i first start it up i hear a "noise" and when i shut it down i also here a "noise"
could this be a "knock"???
After 3 seconds of it running it runs smooth and nice, but i hear a clunk clunk as soon as i shut it off...... I cant tell if it comes from the engine or if its just normal old age noises......
will a knock be pressent all the time???????
-gbm-
Old Feb 15, 2003 | 09:16 PM
steve83's Avatar
steve83
Usually, "knock" means preignition/dieseling/run-on/pinging/detonation/valve tap, which can be caused by several things including a lean mix, low octane, hot spots in the combustion chamber, or high compression. It damages the engine because the pressure & temperature it generates are too high, and can actually burn holes thru the pistons.
"Rod knock" is different, and is caused by the crank bearings being worn out, or from the rod caps being stretched, or just from low oil pressure. Since oil pressure is low at startup, I assume this is what you're hearing immediately after cranking. A cheap mechanical oil pressure gauge will identify this.
I don't know what the "clunk" is at shutdown.
Old Feb 15, 2003 | 09:27 PM
gingerbreadmaniac
Oil Pressure gauge !
got one, i get 15-20 at hot ideal and 40-60 during driving conditions depending on engine temp
Old Feb 15, 2003 | 10:03 PM
steve83's Avatar
steve83
Sounds like your engine is WORE SLAP OUT, or maybe it just needs a new oil pump.
Old Feb 15, 2003 | 10:10 PM
gingerbreadmaniac
what makes you say that????
-gbm-
Old Feb 15, 2003 | 10:22 PM
steve83's Avatar
steve83
20psi at idle (hot or not) sounds pretty low to me. You might get some more life out of it by going to a heavier oil, like 20W50. It's all I ever run.
Old Feb 16, 2003 | 10:41 AM
87black150's Avatar
87black150
According to the Haynes manual, the 300 I6 should have between 40 and 60 psi at 2000 rpm at normal operating temp.
Old Feb 16, 2003 | 02:11 PM
gingerbreadmaniac
20 psi at hot idel is considered to be very addiquite...
-gbm-
Old Feb 16, 2003 | 02:22 PM
steve83's Avatar
steve83
If you consider it adequate, great.
Old Feb 16, 2003 | 05:51 PM
gingerbreadmaniac
dude im fairly sure that 20 psi at HOT idel is normal, maybe someone can jump in here and verifi, my 70 stang 351w with 400+ horse has 20 psi at hot idel aswell
-gbm-
Old Feb 16, 2003 | 07:35 PM
pfogle's Avatar
pfogle
you only need 6psi of oil pressure to keep things from knocking..... I know I had an 82 1 ton van that held NO oil pressure at idle, but had 35 pounds at running speed. I had bad bearings......... reallllllllllly bad bearing. Dura Lube got me and extra 9 months of use out of it.
Old Feb 16, 2003 | 08:12 PM
gingerbreadmaniac
thank you
On a update note i think my shutdown noise is just a exhaust bracket rateling around as the motor gives that last kick before it stops turning.......
-gbm-
