Cummins 5.9l "Big Block" Question
Old Aug 16, 2010 | 07:37 PM
71 Sport Custom's Avatar
71 Sport Custom
In researching motors and cost towards doing a 12v cummins swap I've seen some motors referred to as 5.9 "Big Blocks". Not long blocks but Big Blocks. Looks more on the commercial trucks and not the Dodge pickup apps. Does anyone know if and what the differences might be between the pickup apps and "Big Blocks". I've read the Cummins swap threads here and checked out other forums and can't find any info on what the big block designation means. I can't imagine there'd be block differences without displacement differences. Any help would be really appreciated!!!
Old Aug 17, 2010 | 05:43 AM
mistakenID's Avatar
mistakenID
I've never heard of the "big block" designation referring to the 5.9. My cummings was bought direct from cummins. The manual that came with it has references to industrial and automotive applications.
Mine is a 93 rebuilt by Cummins/Diesel Recon. The turbo, exhaust manifold are different from Dodge. Turbo also sits in a higher more rearward location. Fuel pump is the same, injection pump is the same, factory rpm's set at 2500. Turbo is larger on both exhaust and intake so there is a bit of lag spooling up but it fairly loud when it is spooled up. A quick drop off the throttle under hard acceleration and the turbo really screams.
Internally I have no idea if there are any differences. Starter is different from Dodge. I'm sure the stock injectors are different. Only have 30,000 miles on the engine so have not really done anything to it other than tweaking the injection pump a small bit.
Number21
Large Truck
54
Dec 4, 2017 09:32 PM
uh60
General Diesel Discussion
Dec 4, 2016 10:45 AM
f1001969mike
1978 - 1996 Big Bronco
Aug 15, 2012 04:14 PM
DrkZide
Engine Swaps
Jul 1, 2008 01:29 PM
7.3 Ex
Mar 4, 2006 08:00 AM
