Real-time engine PIDs for 1996?
Old Aug 16, 2010 | 05:30 PM
lasitter's Avatar
lasitter
I've been interested in something like the Edge Insight CTS 83830 for monitoring discrete values for real time engine performance.
It can display up to eight inputs at once, but the number and type will depend on the particular engine and year.
What's the laundry list of traceable values available for the 1996 4.9L six?
Old Aug 17, 2010 | 07:35 AM
lasitter's Avatar
lasitter
Like ...
Injector duty cycle or rich / lean?
Readings from O2 bank sensors?
Engine Coolant Temperature?
Other?
Old Aug 17, 2010 | 03:24 PM
flipklos's Avatar
flipklos
you can get live readings for them from an appropriate piece of equipment.
Old Aug 17, 2010 | 03:50 PM
lasitter's Avatar
lasitter
This I know.
What are the maximum number of readings, and for what outputs, that you can expect for this engine?
Old Aug 17, 2010 | 04:10 PM
gfw1985's Avatar
gfw1985
Cranky Old Guy
I have a Auto X-Ray with freeze frame and monitor, but you never know what it will read till you hook it up, depends on vehicle. Does real good on Ford products, better than other makes, but I couldn't tell you what it would read on your vehicle. The manufacturer of any of them should be able to tell you what it reads for a specific vehicle. Unless tech support is in India like most.
Old Aug 17, 2010 | 04:14 PM
lasitter's Avatar
lasitter
Edge claims that the the Insight reports whatever the PCM reports. That means we only have to know what the PCM reports for this engine for 1996. I figured someone here was bound to know.
Old Aug 17, 2010 | 08:48 PM
flipklos's Avatar
flipklos
Coolant emp, inlet temp, All three O2 sensors. EGR position, injector cycle %, throttle position, RPM, indicated load %, speed, fuel pressure.
Probobly more.
What did you think? its OBD II compliant.
Old Aug 17, 2010 | 09:18 PM
lasitter's Avatar
lasitter
The Edge Insight says it will display up to eight readings at a time. Now I just have to figure out which eight. I'll give the tech support people a call.
Crewdawg141
Feb 29, 2012 09:00 PM
B Dobz
Aerostar
Nov 23, 2010 03:21 PM
Motorhead-42
15
May 14, 2007 07:34 PM
150ford
Ford vs The Competition
37
Apr 19, 2004 08:49 AM
arny
Feb 3, 2004 07:27 PM
