Vapor Lock
Old Aug 16, 2010 | 04:43 PM
raerjim's Avatar
raerjim
Vapor Lock
I had my first run in with the dreaded vapor lock today. 95 deg. doing some idling in town (electric fan on) the truck just lost power, unresponsive to throttle input, coasted 100 yds. and died. Unburned hydrocarbon fumes filled the cab. Would not start till after sitting with hood up for 30 minutes.. I have been collecting parts for a planned engine rebuild this winter which will include an electric fuel pump. I have already picked up a Crane RV cam and timing chain /gears, and best of all, last week scored a set of WORLD Windsor SR. heads on Craigs list (brand new never mounted for 550$!!). i wonder how my motor will look with a bunch of wooden clothes pins all over the fuel lines?
Old Aug 16, 2010 | 05:19 PM
4tl8ford's Avatar
4tl8ford
An overheated coil will act the same way
Old Aug 16, 2010 | 05:51 PM
larryb346's Avatar
larryb346
IN spite of all the talk about vapor lock it is a very rare thing to happen unless you have routed the fuel line closer than the factory setup.
Letting it cool for 30 mins is the normal way a coil going bad acts.
Larry
Old Aug 16, 2010 | 10:12 PM
fifty-two_f1's Avatar
fifty-two_f1
run a hot wire to the coil directly from the battery the next time it happens and try it.
Old Aug 17, 2010 | 04:10 PM
raerjim's Avatar
raerjim
Nothing wrong with the coil, Gentlemen.
Old Aug 17, 2010 | 06:10 PM
mtflat's Avatar
mtflat
I've never experienced "vapor-lock", but I have seen bad coils, bad condensers fuel pump failure and blocked fuel lines........... guess I don't have any solutions to offer.
Old Aug 18, 2010 | 03:13 AM
55 f350's Avatar
55 f350
if it's not the coil and or condenser , and truly is vapor lock well .... i cured mine via an electric pump and i built a homemade , insulated heat shield around the regulator on the firewall . it wasn't pretty but it works . yep i experienced it when the flatty was first fired up and ran for any length of time , and everything was kosher . dain thing was perculating the fuel in the bowl on the pump . the electric was then put on for that reason , and i kinda bent the fuel pump rod when i pulled the pump to take her apart and look and put it back together ............. the incident i had a year or so later that i thought was vapor lock turned out to be a brand new 12 volt coil that when you first checked it cold to warm read right but when it got good and hot whammo it'd strand you !!!!!!!!!!!! i also done what i could to get the lines away from any heat source like the headers .
Old Aug 18, 2010 | 06:02 PM
49willard's Avatar
49willard
Coming cross country in 1978 with Willard flat towing a Model A, the Buick Nailhead (in it at that time) experienced vapor lock. Wooden clothes pins on the fuel line did the trick!
elkhunter
23
Jul 28, 2023 10:48 PM
rifts76
Jun 23, 2013 12:43 PM
B Todd
29
Jun 11, 2013 05:54 PM
dakonthemountain
13
Jul 22, 2005 06:22 PM
traderguy111
Aug 23, 2004 09:46 PM
