Low Fuel Pressure
Old Aug 16, 2010 | 03:42 PM
tctilley's Avatar
tctilley
Low Fuel Pressure
i have a 1995 e350 diesel 7.3L box truck. we have had it computer tested and the only thing that comes up is that it has low fuel pressure...it runs as though it is missing and won't pull itself. does anyone have any idea as to what could be wrong with it?
Old Aug 16, 2010 | 03:55 PM
DRRXR's Avatar
DRRXR
What is the fuel pressure and Welcome to FTE
Old Aug 16, 2010 | 03:59 PM
DRRXR's Avatar
DRRXR
Let me cut to the chase and read this
PowerStroke diagnosis
Old Aug 16, 2010 | 07:28 PM
tctilley's Avatar
tctilley
can the value inside the tank concerning the fuel gauge be bad and causing it to have bad pressure
Old Aug 17, 2010 | 04:39 AM
DRRXR's Avatar
DRRXR
Normally low pressure is attributed to one or a combo of these
Low tank level
Fouled lines
Stuck tank transfer valve
worn out fuel pump
dirty filter
dirty mesh filter at fpr
dirty fpr
dirty vent screen
particulates in the bottom of the fuel bowl
Tank delamination
Algae/Microbial growth in the tanks and lines
Im sure there are a few more someone may want to toss in here too.
Old Aug 17, 2010 | 08:26 PM
tctilley's Avatar
tctilley
do you have a diagram of the fuel pump and where it is located
Old Aug 17, 2010 | 08:37 PM
Hussler's Avatar
Hussler
Here ya go ... https://www.ford-trucks.com/forums/8...-write-up.html
Old Aug 18, 2010 | 12:48 PM
tctilley's Avatar
tctilley
i have a 7.3L diesel...it has lost its prime...how do you prime it?
Old Aug 18, 2010 | 03:14 PM
DRRXR's Avatar
DRRXR
Try filling the fuel bowl with diesel and when it cranks give it throttle til the air gets ot of the line. Get it on the road then and run it.
