Really need some help diagnosing my 1992 f-250
I am having a strange issue with my 1992 f-250 with the 5.8 liter, auto tranny.
It starts up and runs fine-- for a little while. During its first about 15-20 minutes this thing will cruise no problem on the highway at 70-75mph. But once it's hot, it struggles to go 60mph. The truck just seems way underpowered, it revs high and isn't goin anywhere. Almost like driving into a serious head wind.
Any ideas? I can't think of anything that would cause it to be fine when cold then slow when hot. Maybe a tranny issue or transmission cooler issue (if it has one)? How can I tell what tranny I have? I did some research but it seems as if I don't have an overdrive button, so can't figure it out.
Please help, I gotta figure this thing out
Welcome to FTE!
There could be many things causing this. Has the CEL come on at anytime while driving? Have you repaired or replaced anything recently?
As far as the tranny is concerned, your VIN should be on the inside of the driver door and you can use this to determine which tranny you have. I believe you and I have the same tranny and I believe mine to be an AOD tranny. I have a '92, F-150, Auto, 4x4, 302
You can also use the "SEARCH" feature and using Quotes to help find topics regarding your issue.
Someone should chime in later with some ideas, and don't hesistate to POST here what you find out to be the culprit.
No CEL at anypoint, The only thing I've done lately is an engine oil change (did a higher viscosity high milage oil), and front brake pads. I though about a potentially dragging pad but it seems that would cause problems all the time reguardless of running temp.
I did multiple searches but can't find anything that resembles my issue.
http://www.**************/myfiles/transmission.jpg Here is a link to help you identify the trans. If no overdrive and stock then it should be a C6 but check it out to be sure.
Thanks, I've got the C6. Anyone know of an article that can walk me through the changing on my tranny fluid??? I think I'm gonna start there and see what happens.
Again I've used the search and cannot find anything in regards to a c6 fluid change or anyone having the problem I'm having. So any advice on things to check or replace will be helpful. I'm still in the dark on this
https://www.ford-trucks.com/forums/8...d-be-nice.html Have a read through this thread. Some good advice.
