ball joint install
Old Aug 16, 2010 | 08:33 AM
bobmac99's Avatar
bobmac99
ball joint install
'94 F150 2WD. I was installing a new lower right ball joint, and while tightening the castle nut, I finally realized the entire ball joint shaft was turning. Now I can't back it off so as to get the cotter pin in. Should I just forget about trying to put pin in ? Double nut it ?
Old Aug 16, 2010 | 08:58 AM
96ford250's Avatar
96ford250
No put a jack under it and use it to push up on the knuckle
Old Aug 20, 2010 | 06:58 AM
bobmac99's Avatar
bobmac99
yep, that worked. tks !
