2010 A/C issue
Old Aug 15, 2010 | 10:27 PM
JE917's Avatar
JE917
2010 A/C issue
I have a 2010 F250 6.4 extra cab. I have own the truck for 6 months and have 5,000 miles on it. Since we are in the summer months I have been using the A/C more. Doing highway speeds, flat road and the crusie control on, the temperature from the A/C seems to go from cold to cool and then back to cold again. Does a Ford A/C cycle on and off?
The A/C also seems to work better, colder, when I am at a stop light or at low speeds, 35mph. Since this is a new truck I was wondering if something was wrong, or this is how Ford A/C units normally operate. I am use to Toyota A/C which gets the truck cold. Thanks
Old Aug 16, 2010 | 10:41 AM
hhott71's Avatar
hhott71
Buy a thermometer. That way you KNOW the temps, not just a percieved cold/ not as cold/ cold again feeling.
Are you using MAX AC or NORM AC? Max is recirculating the interior air, whereas Norm is cooling outside air. The outside air is at a higher pressure when moving, especially at highway speeds, so it ould be less cool than at slow speeds or stopped.
Old Aug 16, 2010 | 12:22 PM
87 XLT's Avatar
87 XLT
Yep, heres another vote for buying an AC thermometer at any auto parts store.
Just shove it in one of the vents & see what you're getting. This will give you something to tell the dealer.
FWIW, I always run with fresh air on my 87 Ranger, and the temp always runs around 40 degrees.
twin66
1983 - 2012 Ranger & B-Series
Jul 9, 2012 02:51 AM
Samuelito
Electrical Systems/Wiring
Jul 26, 2011 11:33 PM
BlackNGoldRules
13
Jul 23, 2010 08:50 PM
Kokee
Aug 19, 2007 04:30 PM
daddytym
1978 - 1996 Big Bronco
17
Aug 19, 2005 06:22 PM
