So today I pulled and cleaned my EGR valve, I had it parked overnight pointing slightly nose down, but not much (driveway) and I did notice some moisture in the intake, it was kind gooey, oily in there, not dry. Any input would be appreciated.
EGR
Inside the intake port (hard to get a good pic in there).
Crud on the Degass bottle and cap, I dont recall it ever spewing coolant, but it is clear something is going on.
So I shouldnt have any concerns with the moisture in there? Or the crud on top of the degas bottle? Im ordering gauges soon so I can check the coolant and oil temps.
That is really dirty for 34k miles. Do you still have a warranty??
No more warranty...
Code:
The moisture is also caused by the CCV
Being in California there is a limit on what I can do with us now having to smog check our diesels now. Not sure what I can do with the CCV and still pass smog.
You can do a CCV Reroute by adding a Racor CCV6000- or CCV4500. You will still pass smog check. Just keeping the oil out of your turbo and into the Racor filter.
You should not be getting that kind of oil slick from the CCV. I ain't buying that.
Your valve looks not that bad, and the soot looks dry. But the wet look down in the port makes me nervous. But it is hard to tell from a photo. I think you are in for EGR cooler problems in the not too distant future, and time will tell. Or, if you want to be proactive you can have it leak tested.
BTW, the crud on the degas cap supports my theory.
So do I need to take it to a dealer to have it leak tested? What do they check the degas bottle?
It looks normal, DIRTY! I suggest unplugging it so you will not be flowing the exhaust back into the engine.
You should also get your sig going so we know what you love
I'd re-think unplugging the EGR. Chezzit has a thread that's VERY recent about the downside of running with the EGR unplugged. The engine fan may not en-gauge to keep the truck from overheating with it unplugged. I know a couple of us around here have been talking about it. If you want to keep your EGR clean...put a blocking plate between the EGR cooler & the up-pipe.
Like most good threads...this one gets long winded; but there is allot of good information in the first page or so.
