Hello all
First of I want to say that this truck is not going to be any kind of show truck or daily driver, just something "functional" for when I want something with a bed to haul some wood.
With that being said, I need the cheapest, lowest and easiest ride I can get. what is possible?
and thanks in advance, I know this sounds dumb but just easier to be straight forward then to go into detail about everything .
There's cheap and then there's CHEAP. I believe the better approach (or question) would be what components and methods would provide the best value in terms of time, money, and effort.
With that said..... For the rear, look into LMC's Hanger and Shackle Set ($260)
... or if you can fabricate do an axle flip with or without lowering blocks.
Fronts - Cut the front coils but that can throw the alignment out of whack and cause more headaches than its worth. A better solution for ease and ride quality is a pair of drop beams.
Want to go lower? Install smaller diameter tires. Instead of 70 series tires go with an aspect ratio of 60 or lower.
Lowering is just for looks, has nothing to do with anything else.
I don't think cutting the springs would give enough of a drop. But maybe some combination might workk. Is there anything lower then I
I think the rear would be the easier of the two and I could always notch the frame to go lower.
A therere any springs that are shorter that I could replace the fronts with?
shorter springs will not help you, yes it will lower but your alignment will be very off due to these trucks being i beam (think of them as a-arms but instead of mounted on the same side as the wheel. they are on the adjacent side frame rail and 4 foot long, and with the knuckle mounted in it only and not a upper arm like mustangs and such your SOL. on my 66 i bought the JDM 3'' drop beams and i like them. have not lowered the rear yet but got $700 and no problems with the install. im happy and recommended them
so It cost you $700 to drop only the front? using springs?
You can buy new springs for about $75 and cut them to lower the truck, but like has already been mentioned that throws off the camber because of the I-beam suspension.
There is no cheap (inexpensive) way to get the front of these trucks extremely low because of fabrication and/or $500 drop I-beams. You need the $500 I-beams to even get moderately low (3"). Cut springs can get you about 2" of lowering, but you still have to find an alignment shop that knows how to bend the beams to correct the camber issues you've created.
A lot of guys on here have cut coils to lower their trucks and they look good, I've been highly highly considering it for my truck but haven't done it yet, until I finally buy the drop I-beams. $500 is a lot to me, it may not be to some people on here, but it is to me. I just don't know about dropping that much money at once on a truck that isn't my daily driver.
so by cutting coils you mean cutting springs?
and I could get 3" with I beams and another 2" cutting the springs?
im sorry but im not understanding, I must be on stupid mode today or something.
Yes, but the aftermarket beams I believe can't be bent to correct the camber issues. Do a search on lowering and find user JRon and 89fiveohman. They have drop I-beams and cut his coils too, I believe, not 100% sure.
ok, Is there a diagram anywhere of the suspension of a 76-79?
Im thinking if the stock I beams can be bent, why couldnt one just redrill the holes up 2-4"?
Because of the big a$$ cross member that's under there holding them. People have done that before but you can only move the pivot point up about 1-2",I think at the most. Even then I think you have to notch the cross member. Otherwise every time you hit a bump the beams is going to be smacking the cross member. Search in the 67-72 forum for a thread called 68 coming home tomorrow. User Wickedinhere has put air bags on his truck and notched the cross member, he has pics in the thread.
As for a diagram, you can buy a haynes manual and it'll have one in there. Or just go to autozone.com and click on the repair guides after you enter in your truck info.
