Sponsored by: Auxito
starting issues
Old Aug 15, 2010 | 06:07 PM
mbethan's Avatar
mbethan
starting issues
hey FTE this is mike and im new to this but im havin a problem with my 1997 f150 4.6 engine. When the motors cold it will fire right up and run great. BUT when the motor gets to its normal temp and i turn it off it has trouble starting up like it should. Some times it takes over 10 to 15 seconds of it turning over to fire up. IF anybody has had this proplem or has any idea about it please let me know. it will be greatly appreciated.
thank you mike
Old Aug 16, 2010 | 12:35 AM
1975IH200's Avatar
1975IH200
Replace the IAC Valve and gasket.
It is mounted on the drivers side of the throttle body.
Old Aug 16, 2010 | 02:49 PM
mbethan's Avatar
mbethan
thank you for the information.I will try replacing both of those parts and let you know what happens.
thank you mike
