Sponsored by: Kumho
Disc Brake Conversion Help
Old Aug 15, 2010 | 04:34 PM
steven_1104235's Avatar
steven_1104235
I have a ford 9" built for a jeep cj7 i"m working on, and I want to change from drum to disc brakes. I found caliper brackets that use chevy 3/4 ton calipers, but I need to find a 318mm( 12.5" ) diameter rotor that is 5x5.5 bolt pattern. Does anyone know of a vehicle that used this pattern that had disc brakes, I know older luxury cars tended to use larger disc brakes than the trucks and regular cars.
Thanks
Old Aug 16, 2010 | 08:53 AM
mark a.'s Avatar
mark a.
The Lincoln Versailles had 9" disc. Maybe with a little luck you could find one in a old out of the way junk yard in your area ?
