I checked with Ford. They said my truck did not come with Remote locks. But the build sheet says it came with anti theft. Other posts said that if there is antitheft lights on the dash, keyless entry is part of the system. I took down the trim panel below the steering column and there was the module.
F3VF-15K802-Ac (may be 15k602)
55995
ISTC-1422-k1308
FCCID KMH-1K602-RKE3
Question: Will any 1994 F250 remote work? In other words, how do I match a remote to this module?
55995
ISTC-1422-k1308
It's as simple as a remote relearn procedure. Search it in the forums as I forget how to do it now. I believe it allows you to do upto 4 remotes but you have to do all of them at the same time. I have the directions from ford in the wifes truck, 58 miles away! I'll check back if no one posts I'll type it up when I'm home.
I know how to program them. What I need to know is which remote will work with my system? I don't have any remotes and need to buy them. Will any remote for a 94 f series truck or is it specifically tied to this module?
pretty much gotta look like this....any ford key fob that looks like this will work. i think one is from an explorer and another from a taurus or something.i used to work at a car lot,and we had extra fobs .when i bought my truck i didnt know it had keyless entry/alarm til i set the thing off
