Hey guys, this forum has helped me tons with maintenance on my '03 explorer, so first a big thank you to all those that contribute quenstions/answers!!
My issue is a can't locate my Haynes Explorer manual. I've just replaced both upper and lower ball joints, tie rod ends and hub assemblies on both sides. I need the torque specs for the following:
Upper ball joint
Upper Control Arm bolts (2)
Lower ball joint
Outter Tie Rod End
Hub assembly bolts (3)
- found an older post here that states 83 ft-lbs, so just looking for verification on this one.
Any help you could provide would be greatly appreciated!
Found this but it's for a '99, will these be safe to follow for my '03?
Originally Posted by Bill MacLeod
The following is from a 99 shop manual for 4x4 (all in ft.lb):
Lower b/j nut - 83 to 112
Hub to knuckle - 74 to 96
Pinch bolt - 35 to 46
Hub nut - 157 to 213
Upper ctrl arm bolts/nuts - 83 to 112
Sway bar end link nuts - 25 to 34
Again, thanks to the community, you guys are awesome!!
