traction bars
Old Aug 15, 2010 | 08:16 PM
bigbubba87's Avatar
bigbubba87
since were on the building subject what are some ideas for a winch bumper?
Old Aug 15, 2010 | 08:26 PM
megawatt00's Avatar
megawatt00
If I were to build one I would try to duplicate the Ranch Hand styling of them
Old Aug 15, 2010 | 09:17 PM
bigbubba87's Avatar
bigbubba87
ya i like that style more then some out there its square and looks meaner than the rest. is there any way to mount it to the frame better then just using the factory mounting bolts?
Old Aug 15, 2010 | 09:43 PM
WilsonTaylor's Avatar
WilsonTaylor
Originally Posted by bigbubba87
i would have to get longer U bolts but cut a piece of pipe in half that was the same i.d. as the axle o.d. so it would be the same curve as the axle and use the U bolts to hold it on. and weld the tabs on so that they are to the inside of the U bolts
Unless you are not going to be putting very much torque on it, this won't work. The purpose of a traction bar is to prevent axle wrap on a leaf sprung vehicle. If you put enough torque to twist the springs, then it will take more than just friction to prevent it from axle from wrapping. You will need to weld your mounts to the axle tube. Otherwise, once you twist the spring and the mount slips, it will not go back to its normal position. Traction bar mounts are usually welded and have a bushing to connect between the axle mounts and the traction bar. The front mount needs to be able to move from front to back or you will lock your axle into a very short range of motion.
If you want to see some pictures of traction bars, I would recommend that you go over to the forums of pirate4x4.com and look at some of the hard core builds sections. I would also recommend that you just surf. They are not very tolerant of newbie questions in those sections.
Old Aug 15, 2010 | 10:30 PM
sideshow's Avatar
sideshow
not that you'd have to buy this kit necessarily, but you could use it as a guide to make your own. Wide Open Performance - Online Store
Old Aug 16, 2010 | 01:18 AM
bigbubba87's Avatar
bigbubba87
That looks like a pretty good set it would make it alot easier. But i was trying to get out of spending alot of money on it by building in myself.
Old Aug 16, 2010 | 07:10 AM
megawatt00's Avatar
megawatt00
Not that I have seen but I haven't really looked into it to much either, I am sure that it can be mounted differently. What about additional mounting along with the factory bolts?
Old Aug 16, 2010 | 01:46 PM
sideshow's Avatar
sideshow
I hear that, I was just trying to give an idea of how you could replicate what is in the photo. a visual template so to speak. I think Kris (powerstroke junkie) has a gallery of the ones he made. maybe he'll chime in.
Old Aug 16, 2010 | 02:00 PM
megawatt00's Avatar
megawatt00
You are right he did! here is the thread and the link to the gallery that he had the pics in Good Memory bro!!
https://www.ford-trucks.com/forums/8...r-project.html
Traction Bar Project pictures from trucks photos on webshots
Old Aug 16, 2010 | 06:19 PM
bigbubba87's Avatar
bigbubba87
Those traction bars look good. i was thinking about just using round pipe like that but i do not know if it would be strong enough. i want to get a little more hp out of my truck i also work it around the farm
Old Aug 16, 2010 | 07:46 PM
7.3 Rocket's Avatar
7.3 Rocket
If it held up on Kris's truck you won't break it with a little more hp or a farm. I promise.
Old Aug 16, 2010 | 08:00 PM
megawatt00's Avatar
megawatt00
Exactly!!!!!!!! Anything bigger is just for show
Old Aug 16, 2010 | 08:06 PM
  #28
bigbubba87's Avatar
bigbubba87
ok thanks that makes it even simpler lol. i have to remove the factory traction bar right? or can i leave it on
brokeisnojoke
Competition
Sep 4, 2011 07:45 PM
Pickupman2004
May 8, 2008 08:05 PM
jgreen
Offroad & 4x4
13
May 4, 2007 09:50 PM
