Hot Tanking.
Old Feb 15, 2003 | 12:49 PM
erikl85's Avatar
erikl85
Hot Tanking.
I finally got my engine pulled and i understand that if I want to paint it, it would be a good idea to get it hot tanked. From what I understand this involves putting the engine in boiling NaHO (Sodium Hydroxide) or CaHO (Calcium Hydroxide). This just doesnt sound safe to me. Do people do it on their own? If not, where can I get it done? And do you remove the pistons and the crank and what not before doing it? I am assuming any aluminum parts would be no good.
Old Feb 15, 2003 | 07:55 PM
georgedavila's Avatar
georgedavila
Hot Tanking.
Most machine shops doing automotive work have hot tanks. You completely strip the block. You'll need new cam bearings (cheap) and expansion/freeze plugs, also cheap.
Old Feb 16, 2003 | 02:22 AM
airharley's Avatar
airharley
Hot Tanking.
Poor man method is to use easy-off oven cleaner. Not the fume free stuff but the stuff that makes you want to gag when you get a good whiff. takes all the grease and baked on crap right off. Then hit it with paint thinner to get rid of the oils left by your fingers. Just FYI. Also keep it off of aluminum for any extended period of time. It works great to remove corosion off of it though.
Old Feb 16, 2003 | 07:09 PM
jim henderson's Avatar
jim henderson
Hot Tanking.
Hot tanking is a job for professionals, and any bearings in the block will get dissolved.
If you can find it... there was a process called Redi Strip that used a cyanide salt based solution(yeah the poison stuff). It works incredibly well. My old cast iron engine came out looking like aluminum, wow was it clean. Don't know if anyone does this anymore, but it beats the heck out of hot tanking. Be sure to wash off all the salt and it IS poison, no pets please.
Last time I heard of it was in the 80s when I played more seriously with my engines. They were in Rosemead Ca, but I think they moved or shut down.
Hot tanking is OK, but that stuff was amazing, but cost 5X the price.
Good Luck,
Jim Henderson
Old Feb 20, 2003 | 12:01 PM
erikl85's Avatar
erikl85
Hot Tanking.
So, I am going to have to remove the crankshaft? Is there anything special I should know about that?
Old Feb 20, 2003 | 06:44 PM
jim henderson
Hot Tanking.
Don't know specifics on the 460, but in general you want to make sure you don't allow the rod bolts, rods or anything metal to scrape or ding the crank bearing surfaces. Once you get all the caps and seals off it should lift out pretty easy, ooofh. Don't drop it.
You might send the crank out to micropolished, chamfered, radiused and magnafluxed or if it is pretty much stock and in good condition just mic the joournals to check for wear. Of course if you are careful and know what you are doing, you can do the polishing, chamfering and radiusing your self.
A quickie test for a bad crank is to gently tap it on a concrete floor, should ring like a bell.
Good Luck,
Jim Henderson
Old Feb 21, 2003 | 02:30 AM
BIG A's Avatar
BIG A
Hot Tanking.
also keep all of the rod and main caps in order. they HAVE to go back on in the same location and point the same direction they were when you took them off. i use a number stamp set to mark mine if they arent marked
Old Feb 21, 2003 | 02:39 AM
erikl85's Avatar
erikl85
Hot Tanking.
micropolished, chamfered, radiused. OOh that sounds expensive.
Old Feb 21, 2003 | 09:13 AM
georgedavila
Hot Tanking.
Just get it turned .010 under on the journals and mains. The shop will polish and chamfer it as part of the grinding. $150 or so and you'll have a 'new' crank.
You'll have to remove the crank for balancing, so take it in with the rods, pisons, rings and balancer and tell them to turn it before balancing the assembly.
Old Feb 21, 2003 | 10:08 AM
jim henderson
Hot Tanking.
Don't know current methods, but back in the 70s/80s, to do a home micropolish and chamfering just required a steady hand, a dremel tool and stones(for chamfering) and some fine wet/dry sandpaper.
You want to break the sharp edge(if there is one) on all the oil holes with the dremel tool.
To micropolish use very fine sandpaper. I used 600 3M paper, the dark grey stuff. Using some light oil on each journal, I would wrap a piece of paper around the journal and then use a long cloth wrapped around that and then I would pull back and forth on the ends of the cloth to turn the paper to polish the journals. After you are done, clean it off and mic it to make sure of the bearing set you will need. No need for a lot of muscle, you don't want to remove much material, just polish it up.
Be sure to coat the journals with some rust protectant while the crank is out of the engine.
Back in the 70s, a micropolish, chanfer adn magnaflux cot all of about $20.
Good Luck,
Jim Henderson
Old Feb 21, 2003 | 11:32 AM
erikl85's Avatar
erikl85
Hot Tanking.
How much does balancing cost? Do i just take it to a machine shop to do that?
Old Feb 21, 2003 | 02:13 PM
Quantrex's Avatar
Quantrex
Hot Tanking.
A trick to chamfering the oil holes at home; wrap the journals with a layer of masking tape.
Old Feb 21, 2003 | 02:23 PM
georgedavila
Hot Tanking.
$175-200. Most shops have the equipment. I consider it of equal importance to anything else in a rebuild, especially with new components.
Old Feb 21, 2003 | 03:12 PM
77'F-150Mudder's Avatar
77'F-150Mudder
Hot Tanking.
If all you want to do is paint the engine then just use the oven cleaner idea or find yourself a GOOD pressure washer (around 2800 psi will get off almost any crud).
I wouldn't tear apart a good running engine so I could hot tank it just to paint it. As many others have said already, you'll run into additional expenses beyond the $50-$100 a shop will charge you to tank your engine.
Old Feb 22, 2003 | 09:22 AM
georgedavila
Hot Tanking.
From past posts, I was under the impression Erik185 was in the process of building this engine. Like 77'F-150Mudder said, I would tear down a good engine just to paint it.
Nathan511
Dec 8, 2016 11:09 PM
RyRoRyan
Jan 21, 2016 11:35 AM
Old Brown Truck
Oct 31, 2015 10:30 PM
coolfeet
Sep 10, 2015 04:54 AM
MAKO314
Bio-diesel, Propane & Alternative Diesel Engine Fuels
Jun 10, 2009 08:32 AM
