Hesitation and rough idle
Old Feb 15, 2003 | 12:25 PM
chuckles738's Avatar
chuckles738
1989 ford f150 4.9 engine Told to replace egr valve, truck still has a hesitation or a stumbling effect when doing 45 to 60 mph, past 65 it evens out and runs pretty smooth... Also have a rough idle... do all the same things most folks do, new wires .new plugs, rotor , cap etc... replaced 02 , tps, egr valve , and guesss they call it thermoactor valve... Any suggestions to repair these problems would be greatly appreciated!! Thank You All; you have helped me a lot on understanding the operation of my truck, first one I ever had with all these gadgets on it... I like those old fords, last one was a 1970 ford van... Sure had a lot of fun in that ole van Thanks again Chuck
Old Feb 15, 2003 | 01:56 PM
87black150's Avatar
87black150
Have you pulled the codes?
Old Feb 15, 2003 | 02:00 PM
chuckles738
Haven't pulled the codes yet, bought one of those computers to pull the codes from Kragen auto, Going to hook it up and see what codes I get today
Old Feb 15, 2003 | 02:51 PM
Leo_T's Avatar
Leo_T
I had an 85 with that engine. Good engine except for the manifold bolts kept backng off. Check with a wrench, if you can't pull any codes. The engine will run bad if any intake manifold bolts are loose. Similar to what you describe. I ended up taking most of the bolts out and adding lock washers. Just one more thing to check.
Old Feb 15, 2003 | 03:32 PM
steve83's Avatar
steve83
chuckles
You only need a paperclip to pull the codes - the '84-95 EEC-IV scantool is a rip-off. It only does exactly what the Haynes manual and that web page show.
Old Feb 15, 2003 | 03:33 PM
chuckles738
Thanks Leo I'll give that a try today. Hope that solves the problem
Old Feb 15, 2003 | 03:39 PM
chuckles738
Steve Thanks for the info on pulling the codes Chuck
Old Feb 15, 2003 | 04:04 PM
GammaDriver's Avatar
GammaDriver
Based on these boards, and experience with my 4.9, it seems that the V-8's need the EGR passages cleaned out and new EGR's as they get older, but if you mosey over to the Inline Six forum you'll find many of us are actually blocking the EGR pasasges off to get rid of hesitation and stumbling (which is very common in older EFI I-6's until the 'fix' is done) .
Best,
GammaDriver
Old Feb 15, 2003 | 05:24 PM
chuckles738
Thanks Gamma forgot to mention that after installing the new egr valve truck acted the samee stumbling etc. tok off the vaccum line plugged it and now it runs great at any speed, Gonna shoot over to inline 6 forum now....
LarryBee
Aug 12, 2024 06:17 PM
areyou4real
Aerostar
26
Nov 9, 2015 05:19 PM
Big Norm
Jul 21, 2013 12:32 PM
Mannix
Jul 23, 2011 04:27 PM
robertmac
Mar 6, 2008 11:44 AM
