swap motors
Old Aug 14, 2010 | 09:12 PM
imharleysmom's Avatar
imharleysmom
swap motors
I have a 1976 Ford F150 4x4 with a 390 in it, and i was wanting to swap it with my 1977 F150 400 engine, they both have a C6 transmission, will they interchange?
Old Aug 14, 2010 | 09:46 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Is the '77 also 4WD? The bellhousing bolt pattern is different. The C6 trans has an integral bellhousing and can't be switched out. The engine mount towers would also need to be swaped.
Old Aug 14, 2010 | 09:48 PM
imharleysmom
no its a 2wd,,,
Old Aug 14, 2010 | 10:03 PM
79 f-150 guy's Avatar
79 f-150 guy
then you need to find a 2wd fe tranny or you need to take both your c6's and make one out of two using the tailshaft from your 2wd on the 4x4 tranny.. that would be best done at a tranny shop. also you'll need to find the frame perches. i had to buy a whole truck just for the frame perches and the tranny when i did my fe swap.
Old Aug 14, 2010 | 10:24 PM
imharleysmom
thanks for the info
gatorhater
Dec 7, 2014 02:37 PM
CharlieM35
Oct 4, 2012 07:12 PM
nintey4f150
Jul 20, 2010 05:56 PM
Juan_69
New Member Introductions
Nov 16, 2007 07:11 PM
g0226
Oct 29, 2006 11:56 AM
