Problem Starting
Old Feb 15, 2003 | 11:54 AM
86ford's Avatar
86ford
Problem Starting
1986 f150 4x4 5.0 engine
when I first start my truck it is fine, after it idles or runs for a while it is hard to start. went to a parts store and they checked the battery. It read good. Could it be the alternator? Wires are clean, terminals are good. thank you Bill
Old Feb 15, 2003 | 01:27 PM
Franklin2's Avatar
Franklin2
Problem Starting
It turns over good, but won't fire? Or it won't turn over? Or it turns over slowly? Does it make a clicking noise and won't turn over? Will the radio and and other accessories work, but it won't crank?
Old Feb 15, 2003 | 04:17 PM
86ford's Avatar
86ford
Problem Starting
frankin2 thanks it turns over very slowly. no clicking noise. sometimes i have to wait a couple of minutes before it turns over and starts. only does this if it has be idleing or running for a while. one auto part store said the battery was good. he said on fords it is probably ECU. $110.00 another one said ignition modular. $ 50.00 don't know which one to go and get. thank you
Old Feb 15, 2003 | 04:49 PM
Franklin2's Avatar
Franklin2
Problem Starting
If you want to check the charging system, get a voltmeter and check the voltage on the battery with the engine off. Then get it started and check the voltage again. You should get a higher reading than you did when the truck was off. If it's charging, and the battery is good, I would check:
All the heavy wire connections at the battery, the solenoid, and the starter.
Check the heavy ground connection from the battery to the engine block.
I would then change the starter, and possibly the solenoid.
Any bad connections or bad solenoid should get very warm when it's cranking slowly.
jvjaj
1997 - 2003 F150
Nov 30, 2017 11:04 AM
Lance Helmert
Dec 16, 2014 11:26 PM
jwcollin1
1997 - 2003 F150
Jan 31, 2013 11:54 PM
wesayso
2004 - 2008 F150
Mar 21, 2011 05:21 AM
cjsimp1
1997 - 2003 F150
Jan 26, 2009 07:48 AM
