Fan noise
Old Aug 14, 2010 | 04:51 PM
tomfrey's Avatar
tomfrey
Fan noise
There is a fan that kicks on when my truck gets hot,usually when towing up a grade in the tow/haul mode. The same fan also starts up when braking down hill with my trailer in tow. What is that fan ? That same fan recently had a squeal sound when I had a long uphill grade- it was the first time that I heard that. When the long hot pull was over, and the fan came on again, either up another grade or while braking, the squeal was not there....
any thoughts ?
Old Aug 14, 2010 | 08:17 PM
meathead0512's Avatar
meathead0512
mine does same thing but the tach jumps up also and the power sucks?
Old Aug 14, 2010 | 08:30 PM
teppler's Avatar
teppler
I had what I called a high pitched whistle but could be described as a squeal..Had FICM replaced and noise went away..
Old Aug 14, 2010 | 08:34 PM
meathead0512
thanks i will look up fcim dont know squat on working on it 245000 mi and have put lots of money in it
Old Aug 14, 2010 | 09:06 PM
tomfrey's Avatar
tomfrey
Mine sounded more like a bearing squeal. If I stepped harder on the pedal it got louder. It was a long uphill pull and my trailer is appx 9K lbs. The weird part is it didnt happen again.
Old Aug 14, 2010 | 10:07 PM
cheezit's Avatar
cheezit
if the squeel happens only when the fan comes on then you most likly have a failed belt and tensioner. also look at the water pump pully if the center were the belt rides is all silver and not black the pully should be replaced at the same time.
also you need to look at what ect/eot are doing before you wind up with issues caused by a possible pluged oil cooler.
Old Aug 15, 2010 | 07:24 AM
teppler's Avatar
teppler
My squeal or whistle was definately an electronic type noise wondering if the transistors in FICM could be making the noise considering after replacing the noise stopped..
Old Aug 15, 2010 | 08:04 AM
mrford60's Avatar
mrford60
the fan you hear is the radiator fan clutch locking up to give maximum cooling and is putting a load on the belt, causing the belt to squeel or putting a load on the tentioner and the bearing is squeeling.
Old Aug 15, 2010 | 09:44 AM
cheezit's Avatar
cheezit
its not the bearing at all. its the belt slipping under full load of the fanclutch. this happens when the backside of the belt (flat side) geys worn do to a failing tensioner. as a result the water pump pully becomes polished and will nolonger maintain traction with the belt.
Old Aug 15, 2010 | 04:02 PM
meathead0512
replace tensioner and belt that first place to correct thanks
Old Aug 15, 2010 | 05:01 PM
Heckler's Avatar
Heckler
Mine does that as well only when towing uphill, but mine sounds more like a high pitched whine, almost like a radio frequency, could that be the belt and tensioner?
northwindone
Modular V10 (6.8l)
Jun 24, 2015 09:39 PM
Cobra Highboy
Feb 23, 2015 11:59 AM
Macs1964F100
19
Jan 4, 2015 01:57 AM
RadRick
Modular V10 (6.8l)
Sep 10, 2013 12:32 AM
conan777
16
Sep 15, 2005 09:43 PM
