Radiator is Leaking, Should I Delete the Fan.
My radiator started leaking and, when I pulled it there was grass seeds and other trash stuck in the front of it from being driven in pastures. I assume the fan is drawing enough air even when it is not engaged to suck the trash in. This is the final straw for me convert to electric fans. (not that better gas mileage and less noise is not enough.)
I am thinking of removing the fan and clutch while I have the radiator out. The truck will be back in the pastures as soon as the radiator is back in. I will add electric fans before summer arrives. Maybe 2 fans up high and a screen between the bumper and radiator. I am also thinking about 2 fans, one behind or in front of the air conditioner condenser and another just in case the engine gets hot.
Is anyone running without a fan? On the highway in 100 degree heat the fan clutch will engage at the top of a long grade and when I leave the pastures after a 1.5 road of 15 mph. I have not seen a time when the fan is needed except to make the air conditioner work at slow speeds.
Is there any down side to running without a fan for a while?
under 20mph for minutes at a time. (Idling, stop and go, school zones after highway speeds)
OR if towing.
OR if the ambient temp is 60+.
It's hard to quantify and everyone has different states of cooling system efficiency.
If it's a farm truck I'd say you're screwed to pull the fan. Lots of low speed stuff, right? My fan always turns at least somewhat, and that really makes a huge cooling difference.
Also E fans are typically "pull", so they should be mounted behind the radiator. However I got an e fan for an old 81 Celica a while back and though it was listed as "push or pull" you could see that the fan blades weren't symmetrical and it pushed MUCH better than it pulled. So sometimes you gotta see for yourself.
I don't think an e fan mounted in front of the radiator would affect the airflow over the radiator much more than it being behind it. I can't explain it in text form but the difference should be negligible.
-Joshua
I have decided to leave the fan for now and put a screen between the bumper and the radiator. That works ok on my tractor and I did the same on a cab over 2 ton truck. Also, I will put some cardboard over the lower 25% of the radiator until spring. That is where all the grass is collecting and maybe the engine temperature will be a little higher. It stays on the start of "N" and in the summer it will get to "O".
I am running the windstar dual fans. Id say they do the job damn near as well as the mechanical. Radiator is bad inside so it gets hot pulling heavy with either one, but maybe just a little slower witht the mechanical. Honestly, theyre close enough, it could just be my imagination. The dual fan shroud also doesnt completely cover the radiator, about 5" on the bottom with no suction. Fabbin a shroud was going to be a job for this winter if i can ever find the time.
Thank you for the input. I will pick up a set of the Windstar fans some time in the future and search for a controller.
Having the lower 5 inches out of the shroud may be good thing to keep pastures trash out of the radiator. I do not see working the truck that hard or long at slow speeds. I have a tractor to creep a long with heavy trailers.
The truck smokes like crazy when it idles for a long time or has light loads for extended time. It takes about 1.5 on the highway for the smoke to clear. It is probably normal for a 7.3 with 250K but it looks bad so I limit the idle time.
Im thinking the crap you get in the radiator wont be fixed via fan though. Even though my fans are off 99% of the time radiator still picks up a fair bit of sage brush bits and dirt, and im not even out in the crap all that much.
Harris Performance Controls
Is what i have, VERY nice controller and install kit. Really customizable too, you can get the diode pigtail so that you can add other triggers like AC manual switch or anything else you can think of. Good customer service as well.
I actually have the mechanical fan back on it for now until i get some bugs worked out... like a new 3 core aluminum radiator, the afore mentioned shroud fabbed up, and a port in the t-stat housing for the probe.
If youre up for some wiring, you can build your own kit with just the controller. I would recommend F250s thread on e-fans as a guide. I snagged a fuse box out of a 90s sploder for power and auxillary fuse and relay slots to keep it as clean as possible... lots of headache however. Have to pull all the terminals out, which are mostly 16-20ga. and spread them and solder in the appropriate gauge wire and reassemble. the sploder box is long and narrow, which fits nicely next to the stock fuse box under the hood.
Mounting the temp switch on the t-stat or radiator make sense to me. I have also thought about mounting the switch in radiator outlet. Based on the hyper mileage thread, keeping the temp in the 220 range provides the best fuel economy. The radiator outlet temperature could be set to target a 220ish t-stat temperature. You would want a warning light or 238 degree override switch on the t-stat just in case the temp rise through the engine is more than expected. I may be over thinking this.
My new radiator is from Advanced Auto brand name is One Tough 1. The catalog lists it as 3 row but is 2 row. The flutes are at least twice the length of the stock 4 row so the cooling surface should be similar. Plastic top and bottom and the drain and heater are on the wrong sides. It did come with new clips to mound the shroud and radiator. It also came some fin damaged despite begin sealed in the factory box.
The Good: $265 with tax and it comes with a limited lifetime warranty which I have not read but assume they will give you a replacement if it fails. The same radiator is available at other stores and several post indicate 18 months service while others are having better luck. My truck gets driven one or two weekends a month so at this price I can live with the fragile construction.
I would not recommend this radiator if you depend on your truck to make money. Bite the bullet and go to a local radiator shop and have them build a commercial duty unit and gratefully pay the man want every he charges.
