Changed Transfer Case Fluid
Bought this thing about a month ago for super light, low miles duty.
Today, I changed the transfer case fluid.
Fluid: I used valvoline dex/merc auto tranny fluid. I have some full synthetic Amsoil merc/merc V, but I went with the conventional mercon in the T-Case. I was a little nervous about putting merc/merc v in the t-case. I'll use the amsoil on the auto tranny.
I cleaned the grimy tcase with engine cleaner prior to opening drain plugs.
A 3/8" socket drive fits straight into the drain and fill plugs.
I opened the fill plug first and fluid came out. Either overfilled or my driveway isn't level.
I opened the drain plug second and drained completely.
I put the drain plug back and torqued to 18 ft-lb
Then I wondered how the heck to fill the tcase. The fill hole is perpendicular to the ground. I tried a turkey baster, but that took forever. Then I cut up a couple of funnels and pieced them together into a bogus waterfall like thing that seemed to work if I went slowly.
What I really needed was a funnel with a short, flexible hose. The hose could go from the bottom of the funnel into the hole.
I couldn't get the full 2 quarts back in . I got about 1.75 quarts in. I think my driveway isn't level.
I torqued the fill plug back to 18 ft-lb and was done.
Next, I'm going to go into town (with another vehicle) and get a flex funnel. I'll drive a few hundred yards to a flat spot and top off the t-case.
The fluid looked bad. I suspect it has never been changed, which is lame because it's like a 30 minute DIY including cleanup if one has that flex funnel.
The fluid had a few small flakes of a hard yellow substance. Didn't really feel like metal or plastic. Anyone know what's in the tcase that is yellow?
-Island Truck
