gas tank problem
Old Feb 15, 2003 | 10:57 AM
prospector925's Avatar
prospector925
Post gas tank problem
i have a 1986 ford f 150 with dual tanks.the gas guage works when it is on the front tank but when i switch to the back tank it goes to empty even when that tank is full.can anyone tell me how to fix this problem-thanks
Old Feb 15, 2003 | 04:49 PM
Andysutt's Avatar
Andysutt
gas tank problem
bad sending unit. (however you spell that word) Is my guess.
Old Feb 15, 2003 | 06:30 PM
steve83's Avatar
steve83
gas tank problem
You need to test the sending unit circuit from the select switch (known to go bad) back to the affected tank. You might have a bad switch, a bad wire, or a bad sending unit.
Old Feb 15, 2003 | 11:33 PM
Superdave's Avatar
Superdave
gas tank problem
prospector925, Switch to the affected tank. Turn your ignition key forward, but not all the way to start positon. Pull the sending unit wire, ground it to anything, if the circut is good from the plug on connector to the dash, the gauge should peg, then the sending unit is the problem.
Emphasize, make sure you are getting a good ground, when doing this.
TheKhaos
13
Jul 6, 2022 09:57 PM
makattack
Nov 14, 2014 11:47 AM
Mark Mills
Nov 17, 2009 03:29 PM
87f150xlt
15
Nov 9, 2004 12:19 AM
