HPOP question
Old Aug 14, 2010 | 10:24 AM
lrstrck's Avatar
lrstrck
HPOP question
reported a week or so ago about my truck not starting after it was warmed up after a short drive, the codes that showed up were ALL injectors has low circuit. if the ficm is good, would the STC fitting on the HPOP make the truck not start when it gets warmed up. would it show the same codes? and same symptoms?
its a 2005...w/109,000 miles
Old Aug 14, 2010 | 02:53 PM
cheezit's Avatar
cheezit
yes a high pressure oil leak can give you injector ckt faults.
this is caused by excessive cranking till the voltage dorps to around 9.5v
or can also happen when tring to jump start.
Old Aug 17, 2010 | 04:15 PM
Up4anything's Avatar
Up4anything
STC Fitting can definitely make it not start when hot. Had the same issue.
Sixgunjack
Mar 16, 2014 11:17 AM
benb123
Oct 13, 2013 08:29 AM
Mcanx
Jul 3, 2013 04:20 AM
Chris Thomas
Sep 12, 2012 10:46 PM
RaginCajun
Oct 29, 2008 08:11 AM
