Happy friday !
Old Aug 13, 2010 | 06:55 PM
Ottneys250's Avatar
Ottneys250
Happy friday !
Hey everyone I ran into a little problem
When I disassembled my intake the metal harness heat shield wrapped around my bolts so I cant use them no more.
(The old bolts where like 4 diffrent sizes??)
I went to the hardware store and got to diffrent kinds of bolts ones are just a tad longer and the other ones are a tad shorter. Witch do you think would be better? They didnt carry the same bolt.
One last thing I been tryin to delete my smog for a while I also got the block off bolts and serched up some articals and pics. Im just havin trouble findin what to block off...If im on top of the motor say laying down would it be in the center stright down ??
Thanks any help would be the bomb
Kyle Ottney
Old Aug 13, 2010 | 07:03 PM
leavy20's Avatar
leavy20
i always go a tad longer on bolts(if i cant get an exact size)
Old Aug 13, 2010 | 07:08 PM
Ottneys250's Avatar
Ottneys250
Thanks sounds great...No experince on the smog ?
I kinda know what to do ive reserched it alot ive just never seen my motor out, or from the back
Old Aug 13, 2010 | 07:16 PM
96ford250's Avatar
96ford250
Conanski has picks of 351w i believe hes posted them b4 i just cant find where
Old Aug 13, 2010 | 07:18 PM
Ottneys250's Avatar
Ottneys250
I think them where the ones I seen. It was like a before and after pick of the motor out?
(I just have the intake off and thought it would be great to take care of that now)
Old Aug 13, 2010 | 07:20 PM
96ford250's Avatar
96ford250
hes got one of the back of the motor too
Old Aug 13, 2010 | 07:23 PM
96ford250's Avatar
96ford250
found it
https://www.ford-trucks.com/forums/9...re-points.html
Old Aug 13, 2010 | 07:38 PM
96ford250's Avatar
96ford250
thats what you wanted right or am i a tard
Old Aug 13, 2010 | 08:38 PM
Ottneys250's Avatar
Ottneys250
Yes, that helped alot. It got me rollin, I took that back steal peice off...Can I reuse them same bolts and just put some washers at the end of them you think ?
Old Aug 13, 2010 | 08:50 PM
96ford250's Avatar
96ford250
maybe mine werent into the heads they were in the manifolds
Old Aug 13, 2010 | 09:01 PM
Ottneys250's Avatar
Ottneys250
Ehh, I tryed to put it back in ( i been running from the shop to the lap top if you cant tell lol) They fit into that steal peice to screw in, but when its out the bolt needs to be quite a bit bigger.
Old Aug 13, 2010 | 11:54 PM
LCAM-01XA's Avatar
LCAM-01XA
The bolts needed to plug the air-injection ports in the heads are 5/8" regular coarse thread. 1/2" long is what you need, but most hardware stores don't have that, so buy the shortest 5/8" bolts they got then cut them down. You may have to chase the threads in the heads as they often get packed with carbon. After you're done plugging the big ports there's no need to reinsert the small bolts that held the AIR pipe in place, as their holes are blind. Some folks actully don't even bother with the 5/8"bolts, but instead just flip the AIR pipe around and use the smooth surface at its ends to block the ports off, but IMHO this is just rigging it - do it with the bolts and call it good once and for all. Actually they do sell threaded inserts for that very purpose (plugging holes in the heads, not the air-injection ports per se), but 5/8" bolts are cheap and readily available at any hardware store, whereas the inserts may be a bit hard to obtain on short notice.
Old Aug 17, 2010 | 05:44 PM
Ottneys250's Avatar
Ottneys250
Its been a few days, and Im tryin to plug them holes. I thought i read it was a 5/8 but that was quite big (corse thred).
Im pertty shur i tryed every standered size below that...any ideas ?
thanks
Old Aug 17, 2010 | 07:42 PM
LCAM-01XA's Avatar
LCAM-01XA
Well which holes are you trying to plug? The ones I'm talking about are the big ones that meet up with the pipe, yes they are big but so is the pipe...
Old Aug 17, 2010 | 08:33 PM
Ottneys250's Avatar
Ottneys250
Yes, I belive we are. When the stock bolts went into that steal thing they where alot smaller going throught that hole at first then, then the bolt to plug it.
It wouldent be metric would it
