Sponsored by: Real Truck
Creaking/grinding while turning left only?
Old Aug 13, 2010 | 12:15 PM
bigpowerstroke's Avatar
bigpowerstroke
I have a creaking / grinding noise while I turn my truck to the left. I haven't put much time in finding it yet but I was hoping someone has dealt with this before.
It only makes the noise while turning from straight to left, and when you are turning the wheel to the right from hard left to straight. Turning it to the right all the way to hard right makes no noise.
As far as I can tell it IS coming from the left side wheel area but that includes all major steering components and doesn't help much.
Old Aug 13, 2010 | 12:22 PM
sammy77's Avatar
sammy77
Tie rod, Ball joint maybe. Try to isolate noise to identify.
Old Aug 13, 2010 | 02:49 PM
apple1's Avatar
apple1
My cousins f150 did the same thing, ended up being the wheel bearing.
Old Aug 14, 2010 | 11:43 AM
cartmanea's Avatar
cartmanea
Sounds like the wheel bearing assembly.
Old Aug 17, 2010 | 02:20 AM
snakeside's Avatar
snakeside
if its grinding going down the road than take the load off each side by swerving if noise goes away on one side you have your answer
Old Aug 17, 2010 | 03:36 PM
Mr-Pipeline's Avatar
Mr-Pipeline
Could be needle bearings are bad and/or your 4x4 is still engaged on one side. Had the same noise…it wasn’t good. The needle bearings tore up the half shaft and made the wheel bearing assembly very difficult to remove. You just need to get in there and look around…soon.
V8SHO
15
Jun 4, 2016 11:31 AM
F350GK
Feb 18, 2016 11:37 AM
firedaniel
Apr 4, 2015 06:31 PM
4WheelDriveVan
Jan 8, 2011 03:35 PM
dcaprio
May 28, 2009 12:32 AM
