pitman arm nut size
Old Aug 12, 2010 | 06:20 PM
bigbubba87's Avatar
bigbubba87
pitman arm nut size
i have a 00 f350 and my pitman arm nut has worked loose and i was wondering if anyone could tell me what size the nut is? i know its bigger then 32mm and 1 1/4 those are the largest sockets i have found here in town. And also i dont want to start a big debate but i run 15w-40 rotella and a lucas. im out here in laramie wyoming for school i plan to switch to 5w-40 synthetic rotella and synthetic lucas since it gets alot colder out here then it does in missouri and i will not always be able to plug my truck in so i hope with thinner oil i will not have a problem with it starting. after i switch to synthetic can i switch back to regular? and which one is better in the long run for pulling, hot and cold weather, oil change intervals? Thanks Justin
tankd72
Nov 14, 2013 06:44 PM
artfuldodger
Dec 15, 2010 04:39 PM
BillyBob69
30
Jan 9, 2010 12:52 PM
CobraGT40
Jul 20, 2009 06:41 AM
PsD007.3
27
Jan 18, 2009 12:37 AM
