Shift Kit
Old Feb 14, 2003 | 11:27 PM
Matt 390 68 f250's Avatar
Matt 390 68 f250
Shift Kit
Has anybody ever installed a B&M shift improver kit? Is it hard to install? I have a C-6 tranny, Iordered a street/strip kit are they a big improvement from stock?
Old Feb 14, 2003 | 11:35 PM
Ratsmoker's Avatar
Ratsmoker
Shift Kit
I used that shift kit for about three days. I was leaving rubber in both shifts for about 10 feet and it wouldn't shift until it hit about 4 grand. I had it removed by the same tranny guy who installed it. He said he hated them and recommended a transgo. The transgo worked very well. Nice firm shifts without the other problems. Barked second and chirped third but only at wide open throttle. It was behind a 360 in poor condition. I am moving this thread to the tranny forum as it would get more replies that way and that is where it belongs.
Old Feb 14, 2003 | 11:52 PM
Matt 390 68 f250
Shift Kit
So no matter if you were going 20 mph it would still leave a ten foot patch of rubber, when it shifts?(Barely even on the gas?)
Old Feb 15, 2003 | 03:41 AM
1993F150XL's Avatar
1993F150XL
Shift Kit
The B&M kit shifts hard at any RPM. It won't spin the tires at low RPM, it will just shift unnecessarily hard. The Transgo kit is throttle-sensitive. At light throttle, it shifts with close to stock firmness. With heavier throttle, the shifts are firmer & crisper. The Transgo kit is definitely better for a street-driven truck. It gives you the added performance under hard acceleration without the harshness at lower RPMs.
Old Feb 15, 2003 | 07:38 PM
Ratsmoker's Avatar
Ratsmoker
Shift Kit
It took quite a bit of throttle to get to 4 grand just to get it to shift. I didn't know a tranny could shift that hard until I had the kit put in. Of course it didn't leave that much at part throttle but it was quite rediculous. I could still shift from 1st to second manually at any speed just like any C6 will.
Old Feb 18, 2003 | 11:42 PM
Matt 390 68 f250
Shift Kit
I just recieved my B&M shift improvement kit. What do you think about the rv/towing improver vs. the street strip one? The kit lets you choose which one you want. The rv one should be way better as far as shifting at a lower rpm shoiuldn't it? My 268h cam cam today also I will be putting that in pretty soon. I'm pretty exited
reddhawk
Jul 31, 2012 08:46 PM
reddhawk
Aug 2, 2006 07:14 AM
pbear6969
May 1, 2006 09:20 PM
slc10844
Mar 28, 2006 04:46 PM
wildjon300ci
May 31, 2003 10:26 PM
