6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
6.4 with stalling issues.
Old Aug 12, 2010 | 01:01 PM
Txboy08's Avatar
Txboy08
I just bought an 08 F-350 CC DRW with 27000 miles. I've been driving it about a week and the engine will just shut off. If I'm going down the highway I'll fill the truck jerk but the engine will come back on with out having to crank it. The other day I pulled up to a stop sign and it just died but started right back up. It's done it one time where it took about ten minutes before I could get it to start again. I took it to the ford dealer and they said there are no codes in the computer and can't find anything wrong. That was a week ago and they still have the truck. Any ideas what might be wrong. Thanks Daniel.
Old Aug 12, 2010 | 01:10 PM
sdetweil's Avatar
sdetweil
still under warranty.. take it to the dealer..
sounds like EGR valve issue that others have reported..
and welcome to the best place on the internet...
if you get a chance, update your profile a little to tell us here u are,
there are others nearby for sure.. (TX.. means maybe me!)
Sam
Old Aug 12, 2010 | 01:17 PM
Txboy08's Avatar
Txboy08
Thanks for the info and I'll update my profile
Old Aug 12, 2010 | 02:05 PM
senix's Avatar
senix
does sound like a stick EGR valve to me as well.
Old Aug 12, 2010 | 02:16 PM
Maxium4x4's Avatar
Maxium4x4
The exhaust back pressure sensor is known issue, sooting up. Hard to say and with no codes, it leaves little to start with. Hopefully you have a tech who will look at everything.
Old Aug 12, 2010 | 02:36 PM
senix's Avatar
senix
Have them hook up a reader to it so you can take it home and drive it.
Old Aug 12, 2010 | 07:32 PM
ruschejj's Avatar
ruschejj
I seem to remember a post long ago where a cab off repair was done and one of the main wire harnesses was not plugged in/seated fully causing a similar set of problems. There's probably not a trouble code in the PCM for that. Just a loose connection somewhere.
Old Aug 12, 2010 | 07:47 PM
Txboy08's Avatar
Txboy08
Thank you all for the help as soon as I know what the problem is I'll let you know. Thanks again
Old Aug 19, 2010 | 10:29 AM
Txboy08's Avatar
Txboy08
First off want to say thanks for all the help. Finally figured out the problem. It was a broken wire in the main engine wiring harness right next to the PCM. Harness is on order should have the truck back in a few days. Thanks again
Daniel
Old Aug 19, 2010 | 10:45 AM
sdetweil's Avatar
sdetweil
dealer is doing the work? 'truck back in a few days'
Sam
Old Aug 19, 2010 | 11:42 AM
Txboy08's Avatar
Txboy08
Yes dealer is doing the work.
Old Aug 19, 2010 | 04:12 PM
senix's Avatar
senix
glad they found the problem.
NeoCowboy
2004 - 2008 F150
Mar 13, 2021 06:36 PM
Fordbronco69
66
Sep 18, 2016 02:55 AM
The6.0MAN
6.7L Power Stroke Diesel
25
Sep 5, 2015 04:04 PM
cbzdel
Mar 25, 2012 08:18 PM
strokin'_tatsch
96
Mar 3, 2010 09:01 AM
