351w in 69 stepside
Old Feb 14, 2003 | 10:05 PM
Buzzz's Avatar
Buzzz
Thumbs up 351w in 69 stepside
im rebuilding my 351w to put in my 69 stepside i already have a welded 9" rear with 4:11 gears. i have a standard 4 speed with granny for first. im wandering the best tranny for my setup. ive heard the c6 is best but i blew 2 of them when my 351w was in my 74 swb ford. i need a 4th gear because of my 4:11 gear but i cant find an auto. should i change my rear gear or keep looking for a tranny. so far my engine is .030 over and i have a mild cam, roller rockers, headers, intake, carb. i want to stroke it but not sure if i should make it longer or shorter. any info would help, hopefully one day my 69 will run 10's in the qtr.
Old Feb 14, 2003 | 10:25 PM
idealtrucks's Avatar
idealtrucks
351w in 69 stepside
my opinion would be to keep the 4 speed...im partial to a straight shift
Old Feb 15, 2003 | 05:49 AM
jowilker's Avatar
jowilker
351w in 69 stepside
Buzz, What will you be using the truck for mostly? Looks to me like you are building a drag racer with 4.11 gears behind a 351W. In that case grab a top loader from a car.
You said that you needed a 4th gear, well all trannys (non under/overdrive) have a final 1 to 1 output ratio. So a 9 speed tranny will be the same as a 3 spd.
Sounds like your truck had a I-6 in it from the factory and was designed for pulling and a top speed of about 55-60 mph. Not an over the road vehicle.
C6s certainly can be built for drag racing and remain bullet proof.
Good luck on the truck.
Old Feb 15, 2003 | 10:49 AM
Joe fix it's Avatar
Joe fix it
351w in 69 stepside
If that were me (hopefully soon it will be) I would leave the 4spd. Unless you are not comfortably driving standard. The four speed will be a lot more fun to drive in my opinion.
1970 Ford F100 Custom
302 3spd
Old Feb 15, 2003 | 05:11 PM
jowilker's Avatar
jowilker
351w in 69 stepside
But Joe, you only use three of those four gears.
Old Feb 15, 2003 | 06:48 PM
Joe fix it's Avatar
Joe fix it
351w in 69 stepside
In every day driving yes you would only use three of those gears but for havin fun you would use the granny low
302 3spd
