'84 F150 Project
Old Aug 12, 2010 | 07:24 PM
Fordzilla80's Avatar
Fordzilla80
Originally Posted by tjw05
I don't mean to burn you guys, I just don't really like the whole dash-carpet thing. The OEM dash pad's good enough for me. But to each his/her own, right?
I should be able to post pics tomorrow sometime. When I do, I'm hoping some of you more learned guys (fordzilla80?) will let me know what's going on with the front-left. There's some crazy positive camber so that the tire wears really fast on the inside. Does it just need an alignment? I've heard aligning these trucks is pretty involved. That true?
Normally,I don't like them either.The only reason i'm putting one on the F100 is to protect my original dash pad from the sun.
These trucks can be a bear to align.I think it's due to the fact that alot of alignment shops aren't exactly sure how or equipped to align the IFS front.On the 81-96 IFS setups,a special camber adjuster is used to adjust the camber.If I were you,i'd check for bent/worn parts first.Look at all the front components that might cause the camber to be off like it is.If it's crazy camber,then I wouldn't be surprised if something is bent or broken.
kenneBF250V10
Oct 21, 2019 02:44 PM
silar
Sep 10, 2014 06:43 AM
Faber
13
Mar 1, 2014 07:06 PM
IDIDieselJohn
Aug 4, 2011 12:04 PM
PSKSAM2
1983 - 2012 Ranger & B-Series
Jul 29, 2003 09:12 PM
