First year for 7.3
Old Feb 14, 2003 | 07:45 PM
87black150's Avatar
87black150
First year for 7.3
I found a 87 F350 in the paper. I was going to go look at it, but I wanted to know what year the 7.3 came out in. Was it 87 or 88? All the paper says is its a diesel. Thanks.
Old Feb 14, 2003 | 09:46 PM
HoseDog's Avatar
HoseDog
First year for 7.3
I'm not sure about the first year for 7.3 diesel, but don't confuse that with the 7.3 PowerStroke (DIT), which was first available in late '94.
Old Feb 14, 2003 | 10:49 PM
medic641's Avatar
medic641
First year for 7.3
I know an '87 model year ambulance we once had was equipped with the 6.9L diesel.
Old Feb 14, 2003 | 11:38 PM
Redjackt88's Avatar
Redjackt88
First year for 7.3
I believe it was 88' for the first 7.3L. If you look at it, test drive it and look for tranny problems. Electronic Overdrive was very new. Turn the truck on and off a couple times and make sure the tranny shifts correctly everytime. the light should not flash. And if you ever need to have it rebuilt seriously consider the upgraded tranny, you will waste a lot of TIME and MONEY if you dont. $1700.00 in sensors, a rebuild and 4 different opinions has left me with a tranny that on start up sometimes wont go out of 1st gear. Its embarrassing to sit there and restart your truck 4 times before the tranny will finally let you go.
Old Feb 15, 2003 | 12:05 PM
87black150's Avatar
87black150
First year for 7.3
I'm thinking it was 88 too. Not sure though. I called the guy and he said he didn't know if it was 6.9 or 7.3. He owns it and don't know. He did say it was a four speed manual 4x4. He said it was in really good shape, but he's the one selling.
Old Feb 15, 2003 | 02:10 PM
bilder12's Avatar
bilder12
First year for 7.3
The 7.3 was first made available for the 1988 model truck. It was hooked to the C-6 automatic transmission or the 5 spd standard trans. You can tell it is the 7.3 by looking at the heads, which had reinforcing webs between the lower head bolts. Hope this helps.
Old Feb 15, 2003 | 03:10 PM
87black150's Avatar
87black150
First year for 7.3
Yeah, it does help. Thanks! I bet its a 5 speed instead of 4. I'll see when I go look at it. Owner doesn't seem to know much about it.
Old Feb 15, 2003 | 03:26 PM
Redjackt88's Avatar
Redjackt88
First year for 7.3
i am glad to hear its not an auto. but the 5 speed has had problems with the flywheel. when you start it listen and feel for a shudder. also when you release the clutch it may shudder (without accelerating). a friend of mine has a 96' f-350 with a 5 speed and it shudder so hard on a cold start it crack the bell housing in half. My dad's 95 f-350 is also shuddering and my friend's 90' f-350 dump shudders real bad. the auto doesnt seem to have this problem. Just something to look for, hopefully it is a well maintained, low miles diesel with a longlife ahead of it.
Old Feb 15, 2003 | 06:39 PM
87black150's Avatar
87black150
First year for 7.3
Yeah, I know what you mean about the flywheel. We have a 90 F350 7.3 liter that we use as a work truck on our paving company. It has the ZF-5 tranny and it cracked the bell housing on it. Had to pull it and have it tig welded and replace the flywheel. Expensive little boogers too.
bigbubba87
Aug 23, 2014 10:58 AM
Vibrant93
34
Jun 6, 2014 09:50 PM
rockittsled
May 11, 2014 10:31 AM
stonemaster
Nov 24, 2013 09:25 AM
