Assembly process- need advice
Old Aug 11, 2010 | 10:14 AM
CdnWillyG's Avatar
CdnWillyG
I'm starting to assemble my 55 F100 front sheet metal for fitment and alignment. Some parts still need a little cosmetic work but I thought I would test fit everything first just in case some mods had to be made. I'm adding a front tilt hood, so some fab will happen there, door gaps to even out, etc.
Questions:
1) When assembling how easy should the parts fit together, so when they are painted all goes well? As I'm assembling now I need to use a center punch in the holes to get them to line up with a little force in some cases.
2) Do I need to have all the bolts in if it looks good with only a few installed?
3) What is the tell tale that all is aligned properly? I'm thinking the hood gaping to the fenders? (My cab is on new mounting hardware and secured down to the frame.)
Old Aug 11, 2010 | 11:11 AM
sdetweil's Avatar
sdetweil
1, sometimes you have to tweak them a little.. do it now, not after paint. mine lined up perfectly after paint
2, I'm a fan of every bolt hole had a reason.. use it.. Not for alignment purposes tho
for 3, see AXRacers post..
https://www.ford-trucks.com/forums/7...ml#post5984604
sam
Old Aug 11, 2010 | 11:51 AM
CdnWillyG's Avatar
CdnWillyG
Thanks for the link...great write up! I'm assuming with the front tilt hood everything is the same until I mount the hardware for the hood.
Sdetweil, I searched for alignment ...how did you find this link?
Old Aug 11, 2010 | 12:03 PM
sdetweil's Avatar
sdetweil
I knew AX posted it, and so used the advanced search and only looked for his posts.. with 'alignment'
people call me Sam!
Sam
Old Aug 11, 2010 | 06:16 PM
CdnWillyG's Avatar
CdnWillyG
Thanks and okay Sam!
By the way sure like the look of your truck! How long was the build process? Did you do it all yourself?
Old Aug 12, 2010 | 04:05 PM
fking1's Avatar
fking1
I did not pre fit my parts and waited until after paint.
Some front end pieces needed much persuation, but, all finall went together without paint damage.Bed and rear no probs.
Old Aug 12, 2010 | 07:02 PM
CdnWillyG's Avatar
CdnWillyG
I still think I need to pre fit ....not wanting any surprises! I have a little bit of customizing to do so there will be some adjustments to be made I'm guessing.
I somethimes feel that I want to just bolt it to gether and paint it sooooo much easier.
Old Aug 12, 2010 | 08:55 PM
sdetweil's Avatar
sdetweil
Thanks. I didn't do the final paint or the interior, i know my limits. Everything else I did. I prefit everything, you can see pics in my gallery. Still there were a couple places I missed.
We painted everywhere, one piece at a time.
10 yrs start to finish, 5 yrs sitting while I worked on my kids cars.
Sam
Old Aug 13, 2010 | 04:47 AM
dawolverine's Avatar
dawolverine
Always pre fit it'll save a lot of heartache if things go wrong later! It also serves as a good reminder of how everything goes back together, so the eventual final assembly will go easier.
Its also a good chance to check you have all the bits/bolts etc you will need in the correct sizes.
Old Aug 13, 2010 | 06:44 AM
sdetweil's Avatar
sdetweil
and on the doors (or other places where u may have had problems), make sure after alignment to drill pilot holes so you can line everything back up quickly..also saves on scratches..
Sam
devozoo
1997 - 2003 F150
Oct 28, 2010 07:24 PM
quisp
Aug 6, 2010 03:06 PM
johninraleigh
Dec 14, 2009 10:05 AM
robertr
Aug 30, 2007 10:52 AM
