S. California Chapter Join Chapter, Leader:
Please Help
Old Aug 10, 2010 | 10:58 PM
rtorres's Avatar
rtorres
Please Help
Hello everyone!
2004 <NOBR style="FONT-FAMILY: inherit; COLOR: darkblue; FONT-WEIGHT: bold" id=itxt_nobr_4_0>f350</NOBR> PSD 6.0 125000 happy miles. My emmision light came on and my truck lacks power. On start up I dont hear the turbo. What should i be aware of and costs? PLEASE HELP
Old Aug 11, 2010 | 07:34 AM
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
You really need to get the trouble codes pulled and start the diagnosis from there...it could be any number of things.
Old Aug 11, 2010 | 09:06 AM
rtorres's Avatar
rtorres
Thanks Steve. I will be doing that today. Gut feeling is expecting a turbo. If it is a turbo any upgrade recommendations that are cost effective. Thanks again
Old Aug 11, 2010 | 09:14 AM
SteveBricks
FTE Emeritus
They're all pretty costly, but a lot of folks seem to like the Garrett GT3788VA
TurboByGarrett.com - Ford PowerStroke
Old Aug 11, 2010 | 10:11 AM
rtorres's Avatar
rtorres
Steve, one more thing I just called my mechanic who is very honest but it seems he might be on vacation. I live in Whittier and I need an honest replacement do you have any contacts
Old Aug 11, 2010 | 10:19 AM
SteveBricks
FTE Emeritus
Absolutely
OC Diesel Shop - Home of Bud
Give Bud a call...his reputation and quality are second to none. It's a little bit of a drive down to Mission Viejo but it's totally worth it IMO.
Old Aug 11, 2010 | 10:36 AM
rtorres's Avatar
rtorres
Thank you Steve. I appreciate it
Old Aug 11, 2010 | 10:39 AM
SteveBricks
FTE Emeritus
No problem. Be sure to let us know how it works out for you.
Old Aug 11, 2010 | 10:42 AM
rtorres's Avatar
rtorres
I will do that
Old Aug 11, 2010 | 04:21 PM
rtorres's Avatar
rtorres
First code is P2290 icp to low. The voltage is set for 18-24 my read 12. Did get the truck to run and code P2291 came up
Old Aug 11, 2010 | 04:29 PM
bpounds's Avatar
bpounds
You've got 3 threads going. I replied to one.
But I will add here, you might try unplugging the ICP sensor, and see if she runs normal. If so, it is just a bad sensor. If not, then you really do have low injector oil pressure, and it is probably either a leak or a failed pump.
The ICP sensor is on the passenger side valve cover, near the front of the engine.
Old Aug 11, 2010 | 04:34 PM
rtorres's Avatar
rtorres
Thank you I will try that
Old Aug 11, 2010 | 04:35 PM
rtorres's Avatar
rtorres
Bpounds again thanks I too live in whittier maybe Ill see you around.
Old Aug 11, 2010 | 05:48 PM
rtorres's Avatar
rtorres
I just wanted to let everyone know That Bud from OC diesel has been a tremendous help. He is the man
Old Aug 11, 2010 | 05:52 PM
bpounds's Avatar
bpounds
Be sure to let us know how this all plays out.
I've never met Bud, hope I never have to, but he is highly regarded by all reports.
