351m thermostat
I would go with a robert shaw thermostat. They are built to close off the internal bypass when the thermostat opens on the 351M/400 engines. The advance auto, etc will fit but they are not the correct application. I have also ordered motorcraft thermostats from a ford dealer that were the wrong application. The robert shaw number is 333-192, or 333-180, depending on what temperature you want. They are available from flowkooler.com and are $12 - $15.
DanielT28
13
12-13-2012 06:21 PM
cutlass
51
06-16-2011 12:54 PM
1974, 1980, 333, 333192, 351m, bypass, ford, location, motorcraft, replacement, robert, robertshaw, rt139, shaw, thermostat, thermostats, truck
