Just curious?
Old Aug 10, 2010 | 12:35 PM
bulla's Avatar
bulla
Just curious?
How many GPH is my factory fuel pump putting out? And could the racor filter and water seperator be starving it for fuel?
Old Aug 12, 2010 | 04:09 PM
bulla's Avatar
bulla
[IMG]http://i194.photobucket.com/albums/z19/jmsquare/Ford%20F350/CIMG0408.jpg?t=1281647154[/IMG
This is with the key on.
Old Aug 12, 2010 | 04:11 PM
bulla's Avatar
bulla
This if with the key off.
Old Aug 12, 2010 | 04:15 PM
bulla's Avatar
bulla
This is with my key on.
Old Aug 12, 2010 | 04:41 PM
tdpower's Avatar
tdpower
That does look like a lot of air in there. Maybe try a small inline clear filter to rule that out. Here is the 3/8 inch i/o one I have from napa: bk 7309562 (Napa fuel filter) picture by galexander - Photobucket
part number should be below the pic if interested.
Old Aug 12, 2010 | 06:45 PM
Franko72's Avatar
Franko72
Molon Labe
I just put that exact filter on a boat, bought it at ACE hardware. Good little filter.
Old Aug 12, 2010 | 09:50 PM
megawatt00's Avatar
megawatt00
That does look like a lot of air in the filter to me as well.
Old Aug 12, 2010 | 10:03 PM
tdpower's Avatar
tdpower
After looking at the pic again looks like you have a thunderstorm brewing in your fuel filter.
Old Aug 12, 2010 | 10:12 PM
bpowerman's Avatar
bpowerman
I went through a similar experence not to long ago and thanks to these guys I found the problem and got my truck back on the road.
What is the pressure rating on the fuel line you used?
Those fuel pumps can suck a carb rated fuel line flat after the rubber warms up abit. In my case it put me on the side of the road after 10 miles every time. I also found that I was sucking air at the nipple on top of the tank. I used a hand vacuum pump to locate the leak.
When you listed you live data your exhaust back pressure seemed low for towing that heavy of a load. Your boost should reach 20 pretty quick with the chip on. that would give you some where around 40 psi of drive pressure. I don't no if the EBP sensor would pick that up though.
Just some thoughts for you to think about.
Old Aug 14, 2010 | 11:44 AM
bulla's Avatar
bulla
Does anyone else have a filter like thiis that they are running? And are you having any of these air looking bubbles in your filter?
tennesseecoalroller0
Jan 1, 2012 03:08 PM
bassproguy07
Aug 20, 2006 09:13 AM
lpbaca
Mar 29, 2005 08:16 PM
state
Oct 26, 2004 08:15 AM
cajunbronco
Jun 16, 2002 09:56 PM
