coolant flush procedure
Old Aug 9, 2010 | 08:32 PM
eff15thtee's Avatar
eff15thtee
maybe this is a stupid question. the coolant flush procedure in the chilton's manual states (paraphrasing): remove cap on expansion tank,
drain radiator, close petcock, remove thermostat, replace housing (without installing thermostat), remove upper radiator hose at radiator, insert garden hose in radiator. my question is: do you run the engine while the garden hose flushes the radiator or does the flow from the garden hose flush on its own? please, oh please, help!!!
my truck: 2004 (newer body style)
5.4L
Old Aug 9, 2010 | 08:58 PM
Coskid's Avatar
Coskid
No do not run the engine while the hose is running that runs the risk of sucking water into your engine block. It will flush on its own.
Old Aug 9, 2010 | 09:10 PM
eff15thtee's Avatar
eff15thtee
thanks abunch!! sometimes those "low cost" manuals can be a bit lacking.
Old Aug 10, 2010 | 12:30 AM
mikesheldon's Avatar
mikesheldon
Don't even try running the engine without a hose. It is not very much expensive but if u do such a mistake it will create great problem for your car.
texasJ
2004 - 2008 F150
Sep 10, 2014 05:36 PM
whiteboyslo
16
Mar 9, 2014 12:42 AM
dirtriderdan
Nov 23, 2009 09:30 AM
Robbgt
Dec 8, 2006 12:20 PM
allanhilliard
22
Nov 25, 2003 09:33 AM
