Stereo help
Old Aug 9, 2010 | 07:36 PM
Big_Dom's Avatar
Big_Dom
Stereo help
Look I'm trying to put this stereo XHD7720 - AM/FM/CD/MP3/WMA/HD Radio/Bluetooth Ready/iPod Receiver with iTunes Tagging
into my 76 half ton. Its apparently gonna need alot of work, where to start?
Old Aug 9, 2010 | 09:27 PM
Shooter00's Avatar
Shooter00
I popped into a stereo shop the other day, at the begining of my search. It's the kind of place that does high end home theater stuff, swimming pool and hot tub installs, as well as car audio. They don't have the high school kid doing the installs, either. They do a lot of custom and classic car stuff.
They quoted me $30 to install the stereo, and another $30 for the door speakers. He said he'd fab up a bracket and not butcher anything, he'd been doing this for 25 years.
If I were going with a modern head unit like yours, I'd go that route. It's worth $30 for me not to bust a knuckle on that stuff. I'm going with the two **** old school repro stereo from classic car audio like Tees did, so not an issue now.
Old Aug 9, 2010 | 09:31 PM
Big_Dom's Avatar
Big_Dom
Living in where I do that might not be an op, but I'll into it. Thanks
Old Aug 10, 2010 | 09:55 AM
1977f250's Avatar
1977f250
do a search. I have a 90s Ford am/fm casette in mine, with a 10 disk cd behind the seat. A few years back there were a lot of therads on doing this.
Old Aug 10, 2010 | 10:38 AM
berry1234's Avatar
berry1234
That unit will fit. You have to pull your bracket out, cut a hole in the bottom section the size of the sleeve your new radio has. This will leave very thin sections which need to be reinforced. There are pics on a dif. thread of what the person did. Not complicated at all. Once you have the sleeve mounted to the bracket, you can trim the dash bezel with a hacksaw, rotary tool, etc. Search around some more.
Also, for $30, heck yes I would have them do it. It would take me a couple of hours.
Old Aug 10, 2010 | 10:44 AM
Shooter00's Avatar
Shooter00
Not to rip off whoever did this, I copied the pics when planning to do mine. Berry's post reminded me of them, so here they are. Not sure who's handy work it is, but well done....
Old Aug 10, 2010 | 10:48 AM
berry1234's Avatar
berry1234
Thats it! If you can cut metal and drill holes, that bracket is what yours should look like when your done.
Old Aug 10, 2010 | 08:22 PM
fmc400's Avatar
fmc400
MSEE
Those are mine; glad to know they've proved useful. Thanks for the compliments
Old Aug 10, 2010 | 10:15 PM
bucks77ford's Avatar
bucks77ford
That bracket is much nicer than mine.
Old Aug 10, 2010 | 10:47 PM
hasteranger's Avatar
hasteranger
the stereo shop won't use something that nice, btw. They will probably use the plastic metra kit that stereo shops stock. Its fast but I don't think its very sturdy.
Have you considered something like this:
PYLE AM/FM-MPX MP3 Shaft Style Dual **** Radio w/USB/SD - eBay (item 390224457630 end time Aug-12-10 21:09:12 PDT)
or
Dual Electronics XC4100-AM/FM Cass Two-shaft Car Radio - eBay (item 120602543154 end time Aug-29-10 08:08:08 PDT)
They won't play CD's but its a lot easier to keep music on SD cards or an mp3 player anyway! I'm gonna be buying the pyle for my truck, I think. nice that it has a clock, too.
Old Aug 10, 2010 | 10:57 PM
cartmanstwin's Avatar
cartmanstwin
that is an awesome bracket, I just took the one I had, cut it with a metal cutting blade in my body saw. used my leatherman sawblade to cut the bezel, and file to trim the bezel down. then I ran a battery wife for the deck, and I ran new speaker wires, (in the 70's for used a common ground speaker system, and high end decks are not common ground, you'll need a separate ground for each speaker). the rest of the wires are ok, but honestly the only radio wire you'll reuse is the IGN wire, you'll have to tap a light blue/ red tracer wire for lights and the rest of the wires will have to be custom run. I can do it in about a couple hours, but I weld angle iron onto the bracket to hold it, and I reuse the brace for the back too. And, I remove the glove box liner, and the gauges to make wire runs faster.
Old Aug 11, 2010 | 10:30 AM
berry1234's Avatar
berry1234
Originally Posted by hasteranger
the stereo shop won't use something that nice, btw. They will probably use the plastic metra kit that stereo shops stock. .
I don't think they make a Metra style kit for these trucks anymore.
Old Aug 11, 2010 | 10:41 AM
hasteranger
its universal shaft to din
Old Aug 11, 2010 | 11:11 AM
berry1234's Avatar
berry1234
I have seen a under dash kit for shaft or din, and a din to shaft, never a in dash shaft to din that would work in our trucks. Do you have a part #?
Old Aug 11, 2010 | 11:58 AM
hasteranger
no, but I've seen them. I just saw one on ebay 2 days ago actually but now I can't find it.
