6.7l shock absorber performance
Old Aug 9, 2010 | 05:33 PM
thekiwi's Avatar
thekiwi
Anybody else unhappy about how their shocks work when their truck is empty?? The back of my truck bounces alot over small bumps in the road. Certainly not the kind of performance I would have come to expect from Rancho.
On a side note does Bilstein make a replacement set yet??
Old Aug 9, 2010 | 05:45 PM
rdenis's Avatar
rdenis
Nope, not unhappy at all - that's the price you pay for having all that LOAD capability.
You should have bought a 150.
Old Aug 9, 2010 | 06:21 PM
EpicCowlick's Avatar
EpicCowlick
You can always air down the rear tires 10 psi and soften the ride. Makes a big difference over the kidney-jarring 80 psi.
Old Aug 9, 2010 | 06:36 PM
GCLL's Avatar
GCLL
My long bed is smooooth with the Rancho shocks. It's a lot smoother than my 2009 short bed.
Old Aug 9, 2010 | 08:19 PM
FORDTUF1's Avatar
FORDTUF1
I aired down the rears to 70, then to 65, now at 60 or 59. Now the stupid low air chime has to be acknowledged every time I start the truck. The ride is much better and I actually towed my 5th wheel about 20 miles with it, after checking for sidewall bulge and tread patch contact. It did fine but if I was to tow on a trip I would go back to 65 and start there.
I've read my manual about rotating your tires and re-training the sensor location, but I haven't seen anything yet about re-calibrating them for lower pressure, and the event that the next set of tires may have a pressure much lower than 80.
BTW I don't know if the shocks are worth two cents either, they certainly have CHEAP CRAPPY hard plastic covers to make them look like Ranchos. I loved my other SD when I put on Rancho 9000's and wound up putting the rears at 1 and the fronts at 3, this was on a 1 to 9 scale I think it was.
Old Aug 9, 2010 | 08:36 PM
ltatkinson's Avatar
ltatkinson
I have my tires at 55psi in the rear and 60psi in the front. I dont have any chimes going off.
Tim
Old Aug 9, 2010 | 09:19 PM
FORDTUF1's Avatar
FORDTUF1
I have a Lariat, don't know if that matters. Does XLT come with low air pressure sensors?
Old Aug 10, 2010 | 06:51 AM
EpicCowlick
I have a Lariat also. My low pressure warning comes on when any tire is at 62 or less. Very little margin for error. I would like to run the tires at 60 psi but leave them at 65 psi. Seems to be the lowest I can go without dealing with the low pressure alert.
Old Aug 10, 2010 | 08:44 PM
bnmccoy's Avatar
bnmccoy
Might be that the F-350 has the recommended tire pressure higher for the higher load rating vs. the F-250; and same for tire monitoring.
Don't know, just thinking out loud.
Bob
Old Aug 11, 2010 | 02:00 PM
stf26's Avatar
stf26
I dropped down to 65 psi and it made a difference for sure. I just need to get some more of my stuff in the back of the truck to weigh it down a bit. I wonder if there is a way to tell the sensors that you want to be at 60psi.
Old Aug 11, 2010 | 02:06 PM
EpicCowlick
I've been asking around the forums but no one has offered any solutions so far.
Old Aug 11, 2010 | 02:16 PM
sdetweil's Avatar
sdetweil
I don't think ford provides any mechanism for this.. unfortunately..
Sam
Old Aug 11, 2010 | 02:20 PM
stf26's Avatar
stf26
Thats a bummer. Ride quality is really good on smooth roads however there are some roads that are a little intense. Weight is probably going to be the only way to improve the quality without going to a different shock.
Old Aug 12, 2010 | 12:10 AM
kper05's Avatar
kper05
I was unsure if it did, until today.
The TPMS light came on in my truck this morning.
For whatever reason I did have 61 psi in the front right tire when I checked. This evening I made sure my tires were 65 psi in the front and I have the rear set to 70 psi. I have driven 30+ miles since and can't get the darn thing to turn off. I still have the factory Continental 275/65R18 tires.
Hopefully I don't already have a slow leak in that front right tire.
I'll be checking it.
I'm not sure what the special number is but 500 lbs payload changes everything.
Old Aug 12, 2010 | 06:24 AM
stf26's Avatar
stf26
I need to get my toolbox situation figured out and 500lbs here I come....
