Can 4r55e and 5r55e bellhousings be swapped?
Old 08-09-2010, 03:39 PM
Will P's Avatar
Will P
Will P is offline
I have a 01 with a 2.3 that has a dying tranny. It has 220k on it. I found a tranny from an 01 with a 3.0 that only has 34k on it. Can I swap out the bell housings on these so I can install the good tranny behind my 2.3?
Old 08-09-2010, 07:44 PM
Will P's Avatar
Will P
Will P is offline
Let me add a little info. I can't remember what trans code the trucks have but they are both the same. I checked that to make sure. I pulled the 3.0 trans out and it has bolts around the inside of the bell housing that go into the trans itself. I'm assuming that the bell housing can be removed and changed for whatever engine it is going to be mated to. Has anyone ever done this?
Old 08-10-2010, 08:52 AM
ranger pat's Avatar
ranger pat
ranger pat is offline
I would check the gear ratios for 1st, 2nd and 3rd between the two transmissions. I seem to remember the V-6 applications had a different set of gear ratios because to the torque/RPM differences.
nor1168
1999 to 2016 Super Duty
04-20-2023 12:53 PM
01WhiteRanger
04-16-2016 09:27 PM
RojoStar
Aerostar
06-17-2015 07:07 PM
econoconvert
09-14-2012 12:26 PM
ctango01
Engine Swaps
04-26-2010 05:53 PM
Quick Reply: Can 4r55e and 5r55e bellhousings be swapped?
