Erratic Idle??
Old Aug 9, 2010 | 12:51 PM
gspointer's Avatar
gspointer
Erratic Idle??
104K miles on '05 F250 the idle speed started to bounce around after a 30min hwy drive. Put the truck in reverse to turn around and rpm's dropped to ~500 then back up 50-100 over normal. I did not change throttle position much, but it seemed like the throttle wasn't doing anything. I sat and watched the truck idle for several minutes and the idle speed continued to bounce around by 300-400 rpm. Had an issue about a week prior where it fell on its face from about 1200 rpm and ~25mph while barely accelerating wasn't very noticeable at the time due to driving conditions. Looks like I have puked coolant out of the degass bottle and it was empty, about 1/3 gallon. The EGR has been unplugged since 12K and I have had to replace the EGR cooler around 50K. No codes or lights. The truck sat a few hours and drove home fine. I have noticed this summer that the idle was moving up and down about a 100rpms but couldn't remember if that was normal.
Searched the forum a bit, but I haven't been on for quite some time. Hoping to get pointed in the right direction. Thank you!
Old Aug 9, 2010 | 07:12 PM
cheezit's Avatar
cheezit
ok try unpluging the ebp sensor and see if it will still surge. Let me know if it goes away. Do not replace the ebp if it does.
remove and inspect the egr valve for excessive carbon build up.
Old Aug 9, 2010 | 11:58 PM
gspointer's Avatar
gspointer
The problem is intermittant and has not repeated yet. The EGR has been unplugged since about 12k miles were on the truck. I did plug the EGR in for a trip to the dealer back around 50k miles when the EGR cooler needed replaced and they also replaced the EGR at that time, but I unplugged the EGR as soon as I got home. No delete or anything, just unplugged. I would think that would eliminate a dirty EGR, but I am far from being the expert.
I was running Spartain Tow Safe tune, but put back to stock file after checking for codes. I also got chopped the exhaust and ran factor size pipe eliminating the particulate filter and muffler about 84k miles ago. No recent changes though. It is running the inductive heating flash.
Thank you very much for the response!
Old Aug 10, 2010 | 12:05 AM
lakewood's Avatar
lakewood
Could also be the ICP(injector control pressure) sensor. my 05 had similar symptoms and i had a bad ICP sensor and wiring leading to the ICP.
Old Aug 10, 2010 | 02:29 PM
Fungus232's Avatar
Fungus232
X2 on possible ICP. Mine was doing the exact same thing. I just unplugged it and reseated it while it was running and the problems went away (that was a couple days ago). Running like new ever since and I think it wasn't fully seated after my EGR delete a couple months ago. Erratic idle, inconsistent surging while driving and eventually even died on me a couple times at stops. The idle dropped to around 500 rpm, coughed and died in both instances.
Old Aug 10, 2010 | 02:56 PM
gspointer's Avatar
gspointer
Thanks for the responses. I'll check into the ICP sensor and update the status.
Old Aug 19, 2010 | 12:54 AM
joe blow's Avatar
joe blow
gaspointer,
I am having the same issue.....any luck with what fungus232 recommended?
Fungus232,
How long did you unplug it for....was it running etc etc?
Thanks for the help
DaytonaTunnel
1983 - 2012 Ranger & B-Series
Apr 12, 2015 10:12 AM
FRANKIE_FORD
20
Apr 2, 2015 10:34 PM
roostonu
Aug 7, 2014 04:51 PM
LCPullman
17
Jan 11, 2010 01:34 PM
jcstratt
1997 - 2003 F150
Jan 31, 2006 11:28 PM
