87 steering column wiring
Old Aug 9, 2010 | 08:29 AM
va150's Avatar
va150
I have an 87 f350 with a 6.9. The ignition has been tore apart and moved under the dash. I am having problems with the turn signal and warning lights. I suspect it is something in the steering column. How hard is it to tear apart, the steering column? I would like to move the ignition back while I have it tore apart. Where is the best place to get parts if I need them? I will probably have to replace the ignation and turn signal switch. Also the tilt steering does not work, probably need parts for that also. fficeffice" /><O></O>
Old Aug 9, 2010 | 09:29 AM
Franklin2's Avatar
Franklin2
Your easiest solution would be to get the whole complete column from a junkyard truck and install it, since yours has so many problems.
