wierd idling problems
Old Aug 8, 2010 | 10:29 PM
75Three90's Avatar
75Three90
i have to hold the pedal all the way to the floor to get it to start then itll idel real high and for about 5 minutes then itll idle fine and runs perfect. The TPS and somthing else on the throttle body has been changed but i cant remeber what its called its on the throttle body oh yeah its a 1993 4x4 5.0 with a five speed
Old Aug 9, 2010 | 01:31 AM
f-150_1993's Avatar
f-150_1993
ya must be talking about the IAC (idle air control) mounted on the throttle body.
Have you given her a tune-up?
Guys btw especially newbies... I have some sensors labeled and with pics that you can use to identify parts on your 302. Just stop by my profile
and check out the parts & diagrams album
Old Aug 9, 2010 | 01:43 AM
75Three90's Avatar
75Three90
naw james thats been chaged i just couldnt remebr what it was called my dad thinks it might be the throttle body gasket since the guy made a home made gasket for it
Old Aug 9, 2010 | 12:26 PM
f-150_1993's Avatar
f-150_1993
It looks pretty beat up or what?
Nothing seals like the proper gasket.
Old Aug 9, 2010 | 12:45 PM
75Three90's Avatar
75Three90
it looks like it ripples
Old Aug 9, 2010 | 12:49 PM
f-150_1993's Avatar
f-150_1993
So ya think air might be entering thru the rippled gasket?
Is your throttle body clean?
Old Aug 9, 2010 | 12:57 PM
75Three90's Avatar
75Three90
yeah its clean but i think its sucking air around the gasket
Old Aug 9, 2010 | 08:40 PM
hotstang's Avatar
hotstang
Any codes
My 5.0 started acting like this and it turned out to be a bad coolant temp sensor to the computer.
Old Aug 10, 2010 | 09:40 PM
75Three90's Avatar
75Three90
ah thanks man
Old Aug 17, 2010 | 09:53 PM
fordboy5894's Avatar
fordboy5894
could be a fuel pump, or believe it or not even an ignition switch. my buddy has a 302 that would do the exact same thing. we did the pump, didnt do anything. did relays and well, it was the ignition switch suprisingly
Old Sep 2, 2010 | 09:36 PM
75Three90's Avatar
75Three90
thats wierd lol
Old Sep 2, 2010 | 09:38 PM
f-150_1993's Avatar
f-150_1993
so have you fixed it yet?
Old Sep 2, 2010 | 09:46 PM
75Three90's Avatar
75Three90
got the clutch put in it today got some decent rims and tires on it test drove it then parked it,, now its burning real rich and idel high on start up then itll idel fine and wont run rich
Thunderbeam
Sep 7, 2016 11:04 PM
WolfHunter984
Modular V8 (4.6L, 5.4L)
Jul 19, 2016 08:53 PM
Budman1962
2009 - 2014 F150
Jun 20, 2016 09:23 AM
fordguy98
Apr 26, 2015 10:22 PM
wiggles
1997 - 2003 F150
Oct 28, 2003 02:22 PM
