shifting problems
Old Aug 8, 2010 | 04:35 PM
thekingdsm's Avatar
thekingdsm
shifting problems
Sorry if im posting in the wrong place this is my first post. i have a 98 expedition that i just bought from a family member. she had the usual problem with the shifter handle bolts being loose and paid a mechanic to fix it. but after that she couldnt get the trans in reverse. so after sitting a year i bought it and i cant get it in any gear but park and 2, and any other gear is drive. but when the car is off with the key turned i can put it in reverse and n and it will roll. so is it electrical? did the mechanic mess something up? any help would be apreciated.
Old Aug 8, 2010 | 07:43 PM
alloro's Avatar
alloro
The mechanic might've knocked a wire loose at the brake light switch down at the pedal, or blew the brake light fuse. If the brake light don't work then it's not supposed to shift out of park when the ignition is on.
I believe the brake light switch is powered by fuse #13 (15A) under the dash.
Old Aug 8, 2010 | 11:49 PM
thekingdsm's Avatar
thekingdsm
I will check tomorrow for a loose wire, sorry but i meant that the trans will shift out of park but all the gears make me go forward no matter what the pointer is on, but when the car is off i can feel it go in R or N because i can push it.
Old Aug 10, 2010 | 10:30 AM
thekingdsm's Avatar
thekingdsm
Sorry for the late response, a storm knocked the power out. i checked the fuse and the brake switch and both are fine. someone suggested the digital transmission range sensor? does that sound right.
Old Aug 10, 2010 | 06:18 PM
madsonp's Avatar
madsonp
Did you test the brake light/shift interlock switch ? These have contacts in them that can burn out over time. See this post it might help you out. https://www.ford-trucks.com/forums/6...lairified.html
Old Aug 10, 2010 | 10:30 PM
thekingdsm's Avatar
thekingdsm
thanks for the reply. I read the post but it seems to have to do with not getting the car out of park and my problem is that its shifting out of park but every gear makes me go forward. so if i was to turn it on and put it in neutral i would still go forward but if i turn the car off with key in the on position i can feel it roll as though it is in neutral. it seems like the trans is going in gear but the computer is telling the car that it is in a different gear.
Old Aug 11, 2010 | 07:28 AM
Big Greenie's Avatar
Big Greenie
Temporarily Deactivated
There isn't a computer involved. The linkage from the shift handle in the truck down to the side of the trans is a mechanical connection. The display on the dash is also connected to the shifter handle. Sounds to me like the linkage is out of adjustment, and there is possibly a loose bolt at the adjustment point still.
Old Aug 11, 2010 | 11:24 AM
thekingdsm's Avatar
thekingdsm
Ill check the linkage on the trans maybe the mechanic screwed it up. There are only two bolts on the shift lever to connect it to the cable right? But it still confuses me, can it be out of adjustment even when i can count all the gears? And why does it seem to shift into neutral only when the car is off? Sorry for all the questions.
highfly24
15
Aug 1, 2021 11:01 AM
lizzardly
Feb 27, 2015 11:17 AM
60RatRod
Dec 16, 2009 05:45 AM
