I don't know what is up, but the last 2 tanks, the truck gets like 8 mpg! Mods are Banks headers/y-pipe/3.5" cat back, stock cat, banks ram aie, w/ fresh cleaned filter,5-star tuner, fresh oil, fuel filter, and I cleaned the maf and tb. I need to do plugs and O2's (117k on originals), but I can't see that causing the massive drop, used to get 10-12 depending on mix, now 8 even on freeway at 70. drove 60 miles last night and used nearly 1/2 tank!!
Thing is, the motor runs smooth as glass, and monitoring the pids from the scanner shows nothing out of the ordinary.
I see you listed CAI with fresh filter. I don't if you just put it on, but I saw a similar drop after i added a CAI. I put the stock setup back on and the mileage went back up to normal(12-14).
yeah, everything is the same as it has been for the last 5-6k miles, but just recently, the mpg took a poop. good thought though, my old Silvy did the exact same thing.
Could be the winter/summer blend gas, although that should have already happened a while ago, regardless of where you are. Change gas brands lately?
But 8 on the highway? Sheesh. That's horrible. Check your fuel pressure, should be 28-30 at idle, 38-40 at high load (or disconnect the vacuum to the fuel pressure regulator at idle, and it'll go up to 38-40).
lol, I know it is not a boat anchor, or a trailer, since the truck instantly gets 6 mpg the moment it sees a trailer! Maybe.... I have been parking it in the back, next to my car trailer, maybe the truck thinks it will be towing!
I will have to check fuel pressure, and I think I will pull the maf again and clean it, maybe the filter oil got on the wires, idk.
Just a quick thought, are you sure no one has been siphoning fuel from your trucks or maybe you have a small leak in your tank? If it is small enough, the fuel would evaporate and not leave a puddle.
Seems like my mileage has crapped too. My exhaust mods are almost identical to yours(OP) except I use stock intake pieces and no software. I was thinking that the power enrich was on all the time(not sure if these trucks have a power enrich? Feels like it does). I was guessing at the PE because, like you my idle and driving characteristics are flawless and smooth. I was thinking about posting asking if anyone knows about the power enrich and if it can get stuck "on", was unsure..dont wanna get flamed.
