Sponsored by: Real Truck
Disc brakes moan
Old Aug 8, 2010 | 08:47 AM
robertheckmo's Avatar
robertheckmo
Disc brakes moan
My F-350, 2003 has moaning problem (oooooh sound), at slow speed with light pressure on pedal, increased pressure stops sound. I determined it occurs on rear disc brakes. I have done removal, lubed the slide pins, put pads back on. The reason being for not replacing yet, is these pads look new. I also lubed and checked out emergency brake cables for dragging.
Old Aug 8, 2010 | 08:49 AM
redford's Avatar
redford
FTE Leadership Emeritus
Sounds normal to me. My truck does the same thing. Light brake pressure while at a stop with the truck in gear, sometimes the truck will creep forward and the brakes make a moaning sound.More brake pressure stops the sound.
Old Aug 8, 2010 | 02:40 PM
robertheckmo
My master sgt, wife can't accept normal
Redford, My wife is Master Sgt. retired Air Force. And she said " It ain't right, fix it airman, I mean husband!" Thanks for the input.
Old Aug 8, 2010 | 03:44 PM
redford's Avatar
redford
Darn retired Master Sergeants.............
Old Aug 10, 2010 | 02:00 PM
thomabb's Avatar
thomabb
Are the rotors new? My truck did that for a while after replacing the rotors. I usually ask that the new rotors be turned before installation to prevent it, but I forgot to request it last time. It gradually went away.
Old Aug 10, 2010 | 04:43 PM
robertheckmo
thomabb, They are original equip., mine oppsite yours , after 30,000 miles they started their mournful cries. Thanks for the input. Probably ought to replace pads.
Old Dec 11, 2011 | 09:01 PM
Trublufords's Avatar
Trublufords
Watched Two Guys Garage today episode 1014 (on their site says 1015)and the showed a top calipher bolt with a stud on the end that a vibration dampner screws on that should take the dreaded moan that happens from about 20 mph down while braking. Says it is FOMOCO (stamped on part) and is on 2011-12 F150s and can be retro fitted to 150s-250s-350s.Have not found one on a 12 model truck yet -BUT only looked a about 40 trucks so far. Will talk to contacts with Ford this week and try to get a part # and price.To you who consider this normal-- I don't think you have really heard this loud moan.Not a groan noise while sitting at a stop light and lifting foot off lightly off brake pedel and pushing back down!! Blue
Old Dec 19, 2011 | 09:37 PM
Trublufords
Got parts and part #s. Damper asy are AL3Z 4A263 A. List price is $19.33 each, got mine for $15.08 each(2 req.) and stud bolt that replaces top calipher bolt is W715292 list$2.00 each, got mine for $1.30 each(2 reg).Found that these came on 2010 trucks. Regards Blue
Hotpocket
Aug 19, 2012 06:14 PM
makomaker
20
Apr 4, 2012 06:38 PM
bigmomma
Apr 7, 2011 10:48 AM
brwolfjr
13
Feb 16, 2011 08:05 AM
DanZ
31
Dec 20, 2003 12:23 AM
